Breaking chains
Discussion in 'Flatbed Trucking Forum' started by Bdog, Feb 16, 2016.
  1. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    I had a 18,000 lb tracked machine on my trailer today. Secured on four corners with 3/8 grade 70 made in USA chains bought new in November.
    I had them tight with ratchet binders but not overly tight. No cheaters or anything just ratcheted them up like I normally do.
    Drove about 40 miles and pulled over to check the load and the front left chain had broke right near the end where it was hooked to the trailer. Surprisingly the hook, binder, chain were all still there. It broke four links from the hook. I just removed the cotter pin and reattached the hook and continued on my way. It held to the destination. These chains show no damage whatsoever the finish isn't even worn. Just a freak deal and a bad link or something?
  3. AModelCat
    164,992
    Chain is only as strong as its weakest link. Quite possible it was a defective link.
    Bdog Thanks this.
  4. Diesel Dave
    9,729
    33,309
    Jan 20, 2010
    Hesperia, Ca.
    Made in China.....
    baha Thanks this.
  5. Bdog
    1,057
    877
    Nov 6, 2014
    It wasn't made in China. It was a Laclede USA chain.
  6. Diesel Dave
    9,729
    33,309
    Jan 20, 2010
    Hesperia, Ca.
    Everything is starting to be made in China and at the same time companies are trying to keep the good old USA made thing going. I just found out a few weeks ago, even Red Wing boots are made in China. I went to a local distributor to verify and he confirmed, Only a a hand full are still made in USA, but 80% are made in China.
  7. kylefitzy
    kylefitzy Road Train Member
    4,754
    19,808
    Aug 12, 2007
    Kansas city,Mo
    redwing has been that way for close to ten years at least.
    MJ1657 and Diesel Dave Thank this.
  8. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Ratchet binders can put a god awful amount of force on a chain. I've seen them rip spools off trailers before. Always pull on the chain as you tighten to check, just like you would a fan belt. You want it tight, but not so much force it damages anything.
    Edit to add. And never use a cheater bar on a ratchet binder.
  9. LindaPV
    LindaPV Medium Load Member
    Red Wing Worx made in China. High priced spread still made in the USA.
    Diesel Dave Thanks this.
  10. Diesel Dave
    9,729
    33,309
    Jan 20, 2010
    Hesperia, Ca.
    I settled for a pair of Thorougood. Pick up pair at almost half price from amazon $85.00(open box returned) with a tag that say's USA made.
  11. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    They have a mfg plant in red wing mn
