Broken Zerk fittings?
Discussion in 'Ask An Owner Operator' started by Mattflat362, Jul 9, 2016.
  1. Mattflat362
    Mattflat362 Road Train Member
    2,711
    6,228
    Feb 18, 2015
    Avon Lake, Ohio
    How in the heck does that happen? 2 on 1 joint!?
    Has anyone ever experienced a TA doing damage and acting like they didn't or maybe even doing it on purpose to make cash?
    I try very hard to only go to my mechanic but he is off my path. This time I was headed far out of town and felt like I should get greased. That is when a young ### TA tech discovered it.
    Prior to that I had been to another new to me place....Sylvester truck and tire in Avon Lake Ohio near 611/I90. I went there for a alignment and 2 steer tires. I remember them mentioning that they had greased everything up too.....I didn't think much of it until now.
  3. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    Unusual to see them broke off like that, unless his gun got stuck and he jerked it off at an angle.
  4. Mattflat362
    2,711
    6,228
    Feb 18, 2015
    Avon Lake, Ohio
    I agree...makes me want to put cameras on my parking spot!
  5. Ridgeline
    22,727
    123,498
    It rarely happens but when it does, either the joint needs to be replaced or a competite mechanic to remove the remains and install new ones, which they will need to be removed to do the job RIGHT!
  6. Mattflat362
    2,711
    6,228
    Feb 18, 2015
    Avon Lake, Ohio
    I am just tad shocked it happened without some known or accidental persuasion.
    Especially since it was neither was broken on its previous PM.
    Just strange....
  7. Duckman1005
    Duckman1005 Bobtail Member
    28
    21
    Nov 18, 2015
    Sometimes new grease gun tips go on tight and don't want to come off; hence prting it off and snapping the zerk
    Mattflat362 Thanks this.
  8. 77fib77
    77fib77 Road Train Member
    11,677
    77,072
    Jul 7, 2010
    St Louis
    It's not that hard to replace. They are cheap too.
  9. Ruthless
    Ruthless Road Train Member
    9,191
    91,265
    Aug 28, 2010
    The City.
    7 or 8 mm if I recall...been a while. My experience has never been one breaking off tho. Just the little ball/one way valve gets tired n won't hold grease in.
    wore out and 77fib77 Thank this.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had a Freightliner with a blocked zerk. Replaced it with a standard size one, kept getting the ball broken off, it was too tall to clear the axle and would snap off when you applied the brake. Found a lower profile one. Was good after that.
    77fib77 Thanks this.
  11. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    ez out. no corrossion w/all that grease around it. DIY job.
    spyder7723 Thanks this.
