Bubbles in coolant reservoir
Discussion in 'Volvo Forum' started by JPSIPPY, Jun 13, 2019.
  1. JPSIPPY
    JPSIPPY Bobtail Member
    30
    7
    Dec 13, 2011
    cambridge,on
    I got 2015 Volvo D13.and recently I noticed bubbles in coolant reservoir. Took it to Volvo dealers in San antonio TX.they just change filler cap and pressure cap and add coolant above max mark.
    I see no bubbles after that.
    I wonder if that was this easy to fix ,I was thinking about big jobs like injectors, egr cooler, head,or air compressor.
    After they change caps I drive like 1600 miles with light load. Didn't see any bubbles but I see little coolant over flow from filler cap.
    Now I'm confused if my problem fixed or not yet.also had air dryer purge every 10-12 mins now increase to 20 mins.
    Pls give me ur views and if anybody had same problem.
  3. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
    bubbles and coolant puking from overflow is usually head gasket. Your air dryer purging has nothing to do with your motor issues. Your motor drives the air compressor and thats it
    KB3MMX Thanks this.
  4. JPSIPPY
    30
    7
    Dec 13, 2011
    cambridge,on
    Why bubbles disappear after caps changed.
  5. Cam Roberts
    1,621
    1,938
    May 13, 2018
    i wish i knew. thats weird. Bubbles usually not a good sign. but im used to old iron. I dont know, maybe they designed the newer emission trucks to blow coolant bubbles. Just doesnt make sense. someone else that could shed some light on it with more knowledge will chime in soon. wish i could be more help
    JPSIPPY Thanks this.
  6. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Hold up, I know nothing about how a volvo is set up, but a lot of freightliners had head gaskets changed because the heater valve for the sleeper was air controlled and put bubbles in the coolant.
    It is possible that the air comp constantly running may have something to do with it, but like I said, I know nothing about a volvo.
    Rideandrepair Thanks this.
  7. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Because pressure changes cavitation of the water pump impeller.... And controls localized boiling of small hotspots in the motor, usually in the head.(EGR Coolers in Emissions trucks too)
    Low pressure or no pressure in the cooling system can do Very Bad things over time.
    Cam Roberts and Newto Trucking Thank this.
  8. p608
    p608 Road Train Member
    2,181
    2,993
    Nov 10, 2016
    Probably burped itself
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,930
    Mar 30, 2014
    Quite incorrect, unless you put a compressor head gasket in the category of head gasket instead of compressor. The compressor is liquid cooled and they blow head gaskets. When that happens, it will put bubbles in the coolant and blow it out the overflow.
  10. Rideandrepair
    17,575
    56,935
    Aug 8, 2015
    WS also, my 92 had air over electric valves on both bunk and cab.Freightliners not since 99 for sure, maybe earlier. Those things almost cost Me $$$ Once, Luckily figured it out.
  11. Rideandrepair
    17,575
    56,935
    Aug 8, 2015
    Overfilling it will cause problems, fill it cold to cold level. Run a while at idle to get air out, Then it should be good. Cap it, it’s a closed system, level will fluctuate normally as needed for expansion, Hot level goes up, Park it and as it cools level will drop.If still losing AF or blowing out overflow, there’s a problem.
