Bulk Tankers & Aeration
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Oso, Oct 12, 2015.
  1. Oso
    Oso Light Load Member
    217
    107
    Aug 6, 2010
    I've noticed that some bulk tankers have aeration lines going to the bottom of the hopper. My company doesn't use those - we haul plastic. What kinds of products require bottom aeration?
  3. old skool_boyz
    old skool_boyz Bobtail Member
    Oct 12, 2015
    Any ash, lime dust the more powdery material it will stick to the sides and rat hole if you only use top pressure
    Oso Thanks this.
  4. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    753
    Nov 18, 2013
    Tustoned Arizona
    Id say everything can use aeration...Id bet your trailers uses fluffer or vibrator? somehow air has to infiltrate the product right? you not just sending a log of plastic out the back right?Your sending aerated plastic out the back/bottom..
    Id say were all doing the same thing, just different configs
    Could be wrong tho
    Oso Thanks this.
  5. Cheap Weenie
    Cheap Weenie Light Load Member
    152
    148
    Oct 8, 2010
    It's very common for vac trailers dedicated to plastics to not have vibrators/aerators. Plastic is extremely sensitive to contamination and aerators are an easy place for product to get trapped and contaminate the next load. All it takes is a tiny crack in the rubber and you've got a huge-money problem on your hands. It can also cause melting around the aerator if your intercooler isn't totally keeping up. Besides, plastic pellets and powder unload great with top air only, so it's not worth the risks.
    realdesertkickin and Oso Thank this.
  6. Oso
    217
    107
    Aug 6, 2010
    Is plastic less sticky than lime dust or other powdery materials?
    And yes, we do move a lot of powdered plastic using top aerators only.
  7. RockinChair
    RockinChair Road Train Member
    5,386
    14,447
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Yep. The heavier the product, the more important aerators are. Pads are for granular product, and top air is for light, fluffy product like hydrated lime.
  8. Oso
    217
    107
    Aug 6, 2010
    What are pads?
    We use top air for plastic pellets as well. (ie granular product.)
  9. wis bang
    wis bang Road Train Member
    3,455
    4,099
    Jan 12, 2011
    Levittown, PA
    Some trailers use an air pad instead of a flo-cone. Cement hoppers used pads. J model Fruehauf had a flat bottom and a side outlet. the hopper bottom [lid] made an air chamber under the pad and shook the cement out the side... PD bulk railcars can work the same way...
    Google 'airslide' and see some of the first hoppers that looked like double conical tankers, same system was used in railcars.
  10. realdesertkickin
    925
    753
    Nov 18, 2013
    Tustoned Arizona
    Wow, neat to know...be lookin to see what you say next
    I dont know enough to bring a question!! LOL
    My place has so many configs on thier blower trailers, so many (it seems) valve configurations etc etc..A bit intimidating as I put myself out there as an 'everything guy' LOL
    Really need to know, well....everything if possible
    I got my place covered though...cement, flyash, lime, sand etc etc, all the standard hauls...Never using top air (trained not too!)..But now im out there, I see guys giving it a little...Assuming to cut back on unload time
    Gosh, all the food crap too? Flour? Chocalate? Jello!!!!
    Man , im gonna need more training..lol
  11. Oso
    217
    107
    Aug 6, 2010
    Wait - you use bottom air only? How common is that?
    We split the line air and top air about 50/50. Some guys will cut back on the line valve - but no more than half - usually less. For powder we don't pre-pressurize the tank.
