Bushings squeak
Discussion in 'Kenworth Forum' started by Ezeebig, Oct 3, 2021.
  1. Ezeebig
    Ezeebig Bobtail Member
    I have a 2022 t800 tandem dump truck only 8k miles. Front leaf bushing squeaking already but no grease fittings. Just rubber bushings. How can I fix this?
  3. AModelCat
    164,632
    Sure its bushings and not the rubber mounts for the hood?
    Goodysnap Thanks this.
  4. dclerici1
    dclerici1 Medium Load Member
    527
    1,589
    Aug 1, 2012
    Shell Knob, Missouri
    If it is coming from the bushings, I don’t think that there is anything you can do ( outside of of replacing them with greaseable). I believe the rubber bushing type is standard equipment and grease type are an option that would have to have been specified at the time the chassis was ordered. Has it been making noise since day 1?
  5. SmallPackage
    5,777
    18,552
    Dec 20, 2019
    Marion Texas
    Soak with “Super Lube” in the spray can. Grainger carries it. We use it to set rubber and poly bushings in everything. It is about the only thing other than silicone paste that will not damage the rubber.
    Bean Jr. Thanks this.
  6. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Don't normally hear spring pin bushings making noise, I would suspect either hood support rubber cones or upper exhaust stack bushings.
  7. Davis42200
    Davis42200 Bobtail Member
    36
    4
    Dec 7, 2020
    Spray them down with diesel fuel next time you fill up. Easy fix
