Buying a trailer; is this too much rust?
Discussion in 'Ask An Owner Operator' started by motiontruckline, Jan 12, 2026.
  1. motiontruckline
    motiontruckline Bobtail Member
    4
    4
    Jan 12, 2026
    Owner operators I’d like to get your opinion, I found a good deal on an older spread axle reefer trailer, the floor and insulation is solid and it has a new TK reefer unit on it. My concern is some rust on the crossmembers and frame. It’s a 51’ Great Dane with a fixed spread.
    austinmike Thanks this.
  3. Spyro2112
    Spyro2112 Medium Load Member
    626
    436
    Mar 17, 2018
    Surface rust. No big deal, run your finger on the top side of airbag mount, what year trailer don't buy over 10 years
    Siinman, 77fib77 and Opendeckin Thank this.
  4. Spyro2112
    626
    436
    Mar 17, 2018
    Wtf is that wiring on the beak chamber
  5. motiontruckline
    4
    4
    Jan 12, 2026
    The trailer is a 2007. Would it be hard getting loads with it?
  6. motiontruckline
    4
    4
    Jan 12, 2026
    Pretty sure it’s a dump valve lift axle
  7. Spyro2112
    626
    436
    Mar 17, 2018
    Yep. Not alot if people load trailers older than 10 years, plus that's alot of money to dump in to it spend the money on a newer trl.....5 years
    77fib77 and motiontruckline Thank this.
  8. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Could be the ABS sensor wires. That is what mine look like.
    OP if you can get a camera to look at the interior area above the Fifth wheel plate.
    I bought a bargain priced trailer. Planned to R and R the deck. Removed the deck above the fifth wheel plate, all the cross members were compromised with rust. The plate pushed up the cross members from the weight and weakened cross members. All the cross members and the plate needed replacing.
    77fib77 and 201 Thank this.
  9. 062
    062 Road Train Member
    6,346
    34,009
    Oct 20, 2013
    Depends on what you’re going to use it for. If you’re doing mostly fresh 28* and up it will probably do fine. If you’re doing mostly frozen loads, then the unit is going to struggle, even though the insulation looks good it has lost the majority of its R value.
  10. bad-luck
    bad-luck Road Train Member
    3,449
    6,359
    Nov 16, 2013
    Baltimore, Maryland
    Bad idea to by a 51' trailer. Shippers won't want to load you. Buy a 53'
    blairandgretchen Thanks this.
  11. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    Horrible idea. Buy something no older then 5 yrs max. Preferably 3 yrs or newer. I would not run that trailer even if it was free tbh.
    Siinman, austinmike, Concorde and 3 others Thank this.
