Buying a truck For the first time
Discussion in 'Ask An Owner Operator' started by Nevenm91, Nov 21, 2020.
Thread Status:
Not open for further replies.
  1. Nevenm91
    Nevenm91 Bobtail Member
    6
    Hello,
    I am looking to buy a truck and dont have much knowledge when it comes to semi trucks, I want to get into driving the end load dump trailers. Wanted to ask what would be a good truck for me To start ? I have been looking into 06-07 freightliners columbia with Detroit 60 engine but they are hard to find. So what would be another good truck?
    thank You !!
  3. snowwy
    snowwy Road Train Member
    20,639
    13,365
    Jul 6, 2009
    Kw, pete, mack are your better choices if your playing in mud.
    FL isn't built for abuse. Rear ends blow up to easy.
    Nevenm91 Thanks this.
  4. Nevenm91
    6
    I see thank you ! I was looking at mack truck too. As far as miles how big of factor is that i have been trying to get something under 500,000 miles
  5. AModelCat
    166,497
    I wouldn't even look at an aero/highway spec truck for dragging an end dump. Typical fleet specs will work but its not the right tool for the job. You want something built to handle the demands of the job.
    singlescrewshaker and Nevenm91 Thank this.
  6. AModelCat
    166,497
    You find the same rear ends are available in KW, Peterbilt, Mack etc as well. Nothing wrong with a Freightliner if its properly built for the task.
    OldeSkool, haycarter, MACK E-6 and 6 others Thank this.
  7. snowwy
    20,639
    13,365
    Jul 6, 2009
    key word being properly built.. And FL doesn't have the same supplier so i was told.. They're not the same rear ends. They can't handle the abuse.
  8. AModelCat
    166,497
    If you're putting 40k rears in a vocational truck, doesn't matter what brand they are. They won't last. They're a wimpy rear end meant for box haulers. Step up to 46k rears if you need something that will survive.
    Tb0n3 and singlescrewshaker Thank this.
  9. snowwy
    20,639
    13,365
    Jul 6, 2009
    Repeating what the wrecker man said..
    FL is a highway truck. They're not built for dirt.
    They'll haul in the dirt. But if you get stuck in mud. Don't bother trying to get out.
  10. AModelCat
    166,497
    You do realize Freightliner builds more than just POS aero trucks?
  11. snowwy
    20,639
    13,365
    Jul 6, 2009
    Stick With a dirt truck built for the dirt.
  • Thread Status:
