Buying dry van trailer
Discussion in 'Ask An Owner Operator' started by mp4694330, Feb 10, 2013.
  1. mp4694330
    mp4694330 Road Train Member
    1,530
    1,461
    Aug 30, 2010
    Chicagoland
    If You want to buy van trailer what You would do different,
    if You have to do it again?
    New or maybe use, couple years old,what brand?
    Looking for options,
    need 53 air ride,aluminium roof (tired of leaks from plastic one), swing doors, widest possible inside.
    Thanks!
    BigBadBill, buddyvuk and v6killer Thank this.
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    Great Dane 101".
    mp4694330 and buddyvuk Thank this.
  4. UTI TRANSPORT
    UTI TRANSPORT Light Load Member
    126
    53
    Nov 16, 2012
    Great Dane make excellent trailers, that would be my first choice also if you can afford one plus they hold their resale value as well if taken care of. There a plenty of nice used well taken care of trailers out there as well, you just have to look around. Take your time and you will find a nice one..
    I own two Great Dane refer trailers with Spreads one has a 10' and the other a 12' and after owning these two I won't ever own anything else..
  5. MNdriver
    7,985
    4,372
    Feb 24, 2012
  6. UTI TRANSPORT
    126
    53
    Nov 16, 2012
    You can also find some good used if not like new up for auction at auctiontime.com
  7. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Have them and would not do without logistics post
  8. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    I've had great luck with Dane and Utility, poor luck with Watrash (wabash) and Hyundai.
  9. cominghomesc
    cominghomesc Light Load Member
    276
    117
    Apr 20, 2010
    sc
    I like great dane and utility. I would look at getting a plate trailer with logistics post and I dont think you can go wrong
  10. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    I guess this is probably obvious, but the good thing about a van is you should be able to pretty much know what you are getting (compared to a truck). visual inspection underneath, walls, roof, floors, brakes, tires, lights, fifth wheel pin and plate.
    release the brakes and jack up each axle and check the wheel bearings. pull it down the road and make sure it trails straight. make sure the doors open and close correctly, test the jacks in high and low up and down.
    Is there much more to a van than that ?
    UTI TRANSPORT Thanks this.
  11. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    If planning on heavy loads( paper rolls) , go with double cross members. Adds weigh but it will hold up far better in long run. Floor will almost never be a issue with that set up.
