Buying Used first time
Discussion in 'Ask An Owner Operator' started by Kdub99, Sep 19, 2021.
  1. Kdub99
    Kdub99 Bobtail Member
    41
    19
    May 8, 2019
    Was wondering if I could get any input?
    Looking into buying a used peterbilt 389 with a deleted isx15. Truck has 2.2 km (around 1.3mi) and engine is isx15 rebuilt with 500km (300mi) . Tranny and rear ends were done not too long ago. Alot of other stuff has been replace 5th wheel, steering box etc etc.
    not my first time buying a truck but first time looking into a long nose and used. Any things too look for, will it be reliable?
  3. Big Road Skateboard
    7,250
    41,330
    May 2, 2021
    No way to know without getting experienced eyes on it. Even then, it's still definitely a risk.
  4. Kdub99
    41
    19
    May 8, 2019
    For sure will be getting a mechanic to look at it and oil report maybe dyno too if i decide to pull trigger
  5. Spyro2112
    Spyro2112 Medium Load Member
    642
    446
    Mar 17, 2018
    Engine rebuild, paper work, weird Thang to ask is the throw out bering replace?
  6. Last Call
    Last Call Road Train Member
    7,568
    45,914
    Mar 15, 2021
    You better have plenty of extra cash on hand if you buy it cause your gonna be replacing more things if you buy it..
    I would be willing to bet there is alot more things wore out needing replaced.. thats why it's for sale & some somebody doesn't owen it
  7. shooter19802003
    5,654
    42,113
    Feb 8, 2010
    Buying used is always a crap shoot. Just due your homework and check it out. Like anything mechanical, new or old, things wear out and have to be replaced.....no big deal. A truck is a tool, just make sure it is the right tool for the job. The only bad thing about deleted motors and I mean the only bad thing is a shop won't touch them. So you are doing the work yourself, which isn't a bad thing anyways. If it looks good mechanically and drives good, buy it. Don't be afraid of it. Some people in life never take risks and they will never know the satisfaction of success. Good luck.
  8. 201
    201 Road Train Member
    12,853
    26,455
    Apr 16, 2014
    high plains colorado
    Electrical gremlins will drive you nuts, I promise,,
    Last Call Thanks this.
  9. spindrift
    spindrift Road Train Member
    3,235
    12,916
    Dec 2, 2014
    Texas
    If it has been deleted, you better know who wrote that tune. Plus, I'll assume you know a good wrench because no Cummins dealer will touch that engine.
    Speed_Drums Thanks this.
  10. Kdub99
    41
    19
    May 8, 2019
    Engine was done by a reputable local shop. Couple reputable local shops on my area so will get it checked by one of them. And can safely say everything truck has its share of electrical gremlins new or used
  11. Ridgeline
    22,771
    124,457
    No advice will change your mind so buy it.
    Plsdontflip and Last Call Thank this.
