Bypass fuel around ecm on 3406e?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bull hauler, Oct 13, 2012.
  1. bull hauler
    bull hauler Medium Load Member
    300
    80
    Apr 23, 2012
    Anyone done this? Would i get any better flow? Why is fuel routed thru ecm anyway does ecm restrict it?
    thanks for imput
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    One to cool the ecm in summer and two to keep warm in the cold
  4. oilfieldtrash
    oilfieldtrash Light Load Member
    226
    107
    Oct 17, 2009
    Jones,Oklahoma
    It is ran through the ecm to cool it (the ecm, not the fuel). I would expect the ecm to live a very short life if bypassed.
  5. bull hauler
    300
    80
    Apr 23, 2012
    10 4 thanks for imput will leave alone!
  6. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Talk with about this some time ago with one man who's opinion I respect and I was told it is safe to bypass an ECM and run a fuel line straight to a cylinder head. It is needed on dump trucks and other machineries that work hard without anough airflow to cool ECM but for highway trucks it not necesary. Here what he said: It was a thing from the earthmoving side of CAT.
    So if your driving is on highways you can get rid of that restrictive plumbing and go directly to a cyl head. This what I plan to do soon.
  7. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Ya let me know how that works out for ya! Lol.
  8. beltrans
    441
    101
    Nov 26, 2008
    spokane wa
    You do not believe it is up to you! LOL.
  9. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Well to each there own. That's why I would like to hear your results.
    I had a truck with a 1lw in it. I had two ECM failures, and the only thing I contributed it to was the high fuel temps. The truck was plumbed to return fuel to only one tank, and after it has been running a while you could hardly touch the tank it was so hot. After the second ECM failed I changed the plumbing to return to both tanks and that cut the fuel temps in half. I didn't have any failures after that. Call it a coincidence , call it what you want, but they are cooled with fuel for a reason.
    If you think air flow is going to cool it on its own, think of this. Your sitting on a 8% grade for 20 minutes on a 100 degree day with the fan on. Blowing hot air beside a ECM bolted to a engine running 200 degrees.
  10. RHay
    RHay Light Load Member
    107
    17
    Sep 11, 2012
    That ecm is cooled for a reason. Electronics devices can create tremendous amounts of heat.. this isnt a fair comparision but when Google built there new data center near here the pumps they installed to cool all the electronic stuff are capable of 300 gal per minute. Feel around a computer tower or laptop when its in steady use those things make considerable heat.
  11. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    140
    Sep 2, 2008
    MIDLAND, NC
    fwiw- I have bypassed the fuel goijng through the ecm , but spaced it off the block some similar to 6nz.....
    beltrans Thanks this.
