C-12 Jake question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by circle h, Apr 14, 2024.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    I have a 2004 mbl c-12 in a w900b daycab. It always idled a little rough so I finally pulled the jakes and copied all the injector trim codes and got them set. I adjusted the injectors and valves since I was there. It now idles smooth. When I put the jakes back on I found conflicting information on the lash setting. I have always run them at. 045 I found something that said mbl should be .055 . I set them at .055 and I don't have the engine braking that I used to. So my question is can I run the .045 setting? Or was that possibly part of my rough idle.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,593
    6,693
    Aug 26, 2014
    I do not know about those Jake settings but I do not thank that would affect idle. It would affect how your Jakes work when applied. Do not thank they are in play at idle.
    circle h Thanks this.
  4. circle h
    240
    375
    Oct 22, 2020
    Thanks. All six trim codes were wrong. Runs much better now.
    BoxCarKidd Thanks this.
