C-12 No Start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tetemadi, Jan 21, 2020.
  1. tetemadi
    tetemadi Bobtail Member
    24
    Jan 21, 2020
    I bought a non-running military truck that has a C12. The truck is not starting. So far I have verified fuel pressure at the filter housing. I am getting constant power & ground at pins 52/53 & 65/67 and switched power at pin 70. When I turn the key on the CEL illuminates, but goes off after a few seconds. When cranking I don't see the rpm gauge move, not really sure if I should.
    I don't have any CAT diagnostic software or tools. I am going to try and verify crank/cam signal as well as injector pulse on my next crack at it. Any suggestions on what I should try next? If the ecm is damaged, where should I get a replacement or who is recommended in doing repairs?
  3. ClineER
    ClineER Light Load Member
    229
    139
    Apr 27, 2016
    N.E. Oklahoma
    Does it have cruise control, you can pull codes with cruise off and hold set or resume and engine light will flash codes.
    The rpm's should register up to 200rpm while cranking. If there is sensor in bellhousing I would assume that's where gauge gets signal, otherwise from ecm.
    spsauerland Thanks this.
  4. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    Exam failure will have a constant flashing cel. if there is an issue with injectors or sensors while cranking, the cel will start flashing as well.
    I believe your issue is at the secondary fuel filter housing.
    First thing to check is crack the bleeder nut on top of the housing and crank until fuel comes out. Then jump out and only put 20 foot pound of torque on that nut. Try to start again. If no start.
    Do you have a primer pump mounted on the fuel filter base? If not, there is a block off plate. That needs to come off and pump installed. That fixed the same issue you are having on one of my trucks.
    Report back. I can go into a lot to get you rolling but need to get down to the basics
  5. tetemadi
    24
    Jan 21, 2020
    Doesn't have a cruise control button. I figured I should see something on the rpm gauge when cranking, but it doesn't even move. I am going to pin out the crank signal to see if it's sending anything over to the ecm.
    If the ecm was completely gone, would the CEL flash? I'll check for fuel at the bleeder. When cranking we cracked the supply line going into the filter housing and fuel was spraying out when cranking. I am also going to put a fuel gauge at that bleeder port. It does have a primer pump.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Have you looked for a TM (technical manual) online? I was Army, but sure Marine core has them for the MTVR. If gauges were multiplexed, they would sweep @ key on. I think tach should be showing RPM, but need a wiring diagram for the chasis. Does check engine light come on steady if you disconnect say the boost sensor?
  7. tetemadi
    24
    Jan 21, 2020
    I wish I had a TM for this truck, but they haven't been released. A few months ago these trucks were released to the public, so they are still new to us and we are trying to get manuals. Okay, so the oil pressure and water temp gauges sweep when the key is on. I will try disconnecting a sensor(s) to see if the CEL light comes on.
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    T
    That means multiplexed gauges (assuming), so usually tach doesn't show at first, then does. I hate the stuff, but does it start with starting fluid?
  9. tetemadi
    24
    Jan 21, 2020
    Yes it will run of starter fluid and we tried a gas rag.
    The gauge shows about 1100 hours and 7500 miles.
  10. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    What voltage is @ ECM and did you load test wires with headlight bulb. Might be 24V, might 12V ECM.
  11. tetemadi
    24
    Jan 21, 2020
    24.5v. I haven't load tested them. From what I read, the ecm accepts both 12v or 24v. The ecm also looks original, the painted bolts look untouched.
