C 15 Fuel Filter Valve
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 04 LowMax, Nov 13, 2013.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    I have read that when you get an ecm reflash that you should also close the fuel return valve at the filter base to force more fuel through the pump. If someone could please explain the mechanics of what this does it would help me to understand. I can see that it would likely have a positive effect on hp, but it seems that by forcing more fuel into the engine, it would have the opposite effect on mileage. I have run a couple days now since the tune, and with it closed, and while I for sure have more power, I don't yet know about mpg. One thing I did notice, is that the fuel in my tanks is no longer nice and warm like it used to be. It seems to me, that warm fuel in the tanks when you operate in a winter climate where temps can get easily to -40 is not a bad thing. I remember running through the dakotas and minnesota in the 80's during some nasty winter weather, and while many trucks were dead in the water with frozen fuel lines, my old screaming 8v92 detroit "green leaker" kept on chuggin, with warm
    fuel tanks due to a lot of return. Feedback appreciated. Thanks.
  3. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    140
    Sep 2, 2008
    MIDLAND, NC
    I would NOT block return. If later engine install 3049385 check valve
  4. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Anyone else help on this one? The guy who did the reflash for me said to definitely close this valve. It doesn't seem to totally block the return fuel, just some of it. The fuel in the tanks is still a bit warm, just not as warm as it used to be.
  5. cat from the valley
    cat from the valley Medium Load Member
    469
    32
    Dec 8, 2008
    jamaica
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    I believe that valve only returns more fuel back thru the fuel water separator, mine is always closed, all the local cat shops around home say to leave it closed, and when it starts to leak fuel or suck air remove it and don't put another one back on.
    04 LowMax and Cetane+ Thank this.
  7. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,435
    Dec 31, 2010
    Alberta
    IIRC, Kurt (Mr Haney) also recommends closing it.
    Cetane+, rollin coal and 04 LowMax Thank this.
  8. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Was he talking about the small tap that some engines have to return warm return fuel to the transfer pump? I believe this was installed on some for cold weather operation.
  9. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    yes thats the one
  10. morehp
    699
    206
    Jun 18, 2012
    Turn it to the off position .
  11. ROBSREDFORD
    266
    140
    Sep 2, 2008
    MIDLAND, NC
    Agree to close the one that loops back to transfer pump ...but did not read it that way from your original post...
