C-15 Low boost @ high RPM
Discussion in 'Kenworth Forum' started by Twood99, Feb 13, 2015.
  1. Twood99
    Twood99 Bobtail Member
    Having a strange problem with my 6nz. Keep getting boost pressure loss and surging at high RPM, 1700 to 1850. Have pressure tested air to air all boots and clamps. Is it time for a turbo? 1.1 million on engine and turbo. Have never had this issue before with any of my cats.
  3. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Bad throttle sensor possible? Run on cruise not pedal and see if surging continues. Boost sensors are known to stick also. Not turbo. Could be wiring problem, start eliminating and keep us posted.
    Twood99 and unloader Thank this.
  4. Twood99
    Changed throttle sensor and still have same issue. Going to start looking at ECM or injector wiring.
  5. Twood99
    New JMT turbo installed, no change. Has anyone had this happen from a bad check valve on compressor? It could allow boost to escape from intake? Might be my next move, will advise if this changes anything.
  6. autogod
    autogod Bobtail Member
    Just some ideas : have you checked air and fuel filters.
