c-15 water temp
Discussion in 'Ask An Owner Operator' started by futurenow, Dec 2, 2012.
  1. futurenow
    futurenow Bobtail Member
    20
    Feb 22, 2009
    Norfolk, VA
    I've got c-15 & my water temp use to be around 175 on normal driving..now it runs up to 190 & back to 175'''on normal driving "- flat roads...I changed thermostat.& flushed..runs normsl at 175 but if I turn my truck off & start back up again.. it will start fluctuations again...oil good & water clean....thinking water sensor ,but not sure...any ideas....thx in advance..oh yea,,it doesnt run hot,,
  3. rollin coal
    rollin coal Road Train Member
    13,649
    28,062
    Mar 29, 2008
    TN
    When's the last time you washed the radiator out? Likely has dirt clogging the fins. Water hose and use a pesticide pump sprayer to shoot some simple green or some other mild surfacant/detergent in there. Do NOT use a high pressure washer. Garden hose low press only..
    futurenow Thanks this.
  4. futurenow
    20
    Feb 22, 2009
    Norfolk, VA
    thx,,I'll givd that a try..I blew it out about 7-months ago with my air gun
  5. rollin coal
    13,649
    28,062
    Mar 29, 2008
    TN
    I wash mine out every couple of months just routine maintenance it's a good practice.
  6. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    Had the same problem for a few months, aired out tge radiator and it was fine after that for a week or so; ended up getting a new radiator cuz the old one had a hole in it :( but it fixed the issue!
    Try AIRING out your radiator; dont use water cuz dust and bugs can stick to it.
  7. futurenow
    20
    Feb 22, 2009
    Norfolk, VA
  8. futurenow
    20
    Feb 22, 2009
    Norfolk, VA
    thanks for all the advice..
