c12 head cracked
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shadowrider1, Sep 9, 2013.
  1. shadowrider1
    shadowrider1 Bobtail Member
    30
    4
    Aug 15, 2010
    evadale Tx
    I have a 2003 pete with a cat c12.the head cracked on it. Does anybody know what different year models will fit or does it have to be off of a 2003 having trouble finding that year and was just wondering what other year models will fit thanks
  3. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    You need the same series engine serial number. There are newer models cylinder heads and you can't mix them up with the old style..
  4. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,041
    Dec 17, 2008
    You should be able to find a head off of either a serial number prefix 2KS C-12 or a MBL C-12 that will work. The 2KS will be from 2000 to 2003 model year trucks. The MBL will be from 2003 to early 2004 model year trucks
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    What is the difference between the 2KS and the MBL bridge engines anyway? Is it just an ECM flash for better emissions until the C13 Acert came out? Also are the 3CS and MBJ C10 heads the same?
  6. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Mbl is a 70 pin and has a few updates with the cam followers I believe. They had a low nox tune and a catalytic converter.
