C13 engine coolant temp and fan issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 2006gmcdmax, Feb 20, 2018.
  1. 2006gmcdmax
    2006gmcdmax Light Load Member
    67
    26
    Jan 31, 2018
    I have a 2005 pete 378 with a c13. I’m having a issue where the gauge in the cab says the truck is running 200-225. I’m scared to let it keep running hotter just to see if the fan is coming on. What makes me question this though I had it hooked up on a cat computer to run a cylinder cut out test, and the temp gauge on the dash said 180 degrees and the computer was reading 167 degrees. Which in that case I drove the truck about 10-15 minutes to the shop. If the truck was actually trying to run hot wouldn’t the fan come on at cats desired 217? Also the cab gauge obviously was reading different than the ecm by 13 degrees so wouldn’t the temp gauge have to show 230 degrees for the fan to really come on at 217? How do I fix this problem? the fan in this truck has never cycled right in my opinion unless the ac is on.
    A5¢ Thanks this.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    On an 05, the dash and ECM get info from different sensors. Need an infrared gun to verify which one is correct first.
    A5¢ Thanks this.
  4. 2006gmcdmax
    67
    26
    Jan 31, 2018
    Ten four will do I have one I keep in my truck
    A5¢ Thanks this.
  5. 2006gmcdmax
    67
    26
    Jan 31, 2018
    I was thinking of putting a mechanical gauge in it
    A5¢ Thanks this.
  6. 2006gmcdmax
    67
    26
    Jan 31, 2018
    Does the temp sensor hooked to the ecm actually control the guage
  7. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Both temp sensors while be on thermostat housing on a C13. Cat one will be hooked to cat harness/mesh style covering that is tougher than steel to cut. Pete harness will have convulted plastic split loom.
    A5¢ Thanks this.
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    05, No. Two separate sensors.
  9. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    fan will cut in at 103 deg C engine coolant temp 73 deg C inlet air temp and when ever cyled by the air con. Generally I value 5V analog data higher than a 2 wire thermal resistor.
    A5¢ Thanks this.
  10. Hadenough
    Hadenough Bobtail Member
    I just purchase a 2006 sterling 9500 series!
    What should the normal temp reading be
  11. Freightliner Classic
    Freightliner Classic Light Load Member
    108
    98
    Dec 17, 2018
    Rome GA
