C13 oil leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by cat13, Feb 14, 2017.
  1. cat13
    cat13 Light Load Member
    192
    60
    Jul 8, 2013
    Central FL
    Trying to track an oil leak on the back of the head. Valve and rocker box gaskets changed about 14k miles ago but didn't help. Has a fairly steady stream running down passenger side rear of block. Losing 1/2 - 1 gallon a week mostly from this leak.
    2004 c13 kcb in a freightliner columbia
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    When did you notice the leak was it after the valve cover gasket was changed. I had it happen to me. The gasket was crimped. I would look at that.
  4. cat13
    192
    60
    Jul 8, 2013
    Central FL
    Dealer changed valve and rocker box gaskets for me because of the leak. Paperwork claims it was the rocker box originally leaking but doesn't appear to have changed since it was done. Doesn't appear to be from the valve cover. All the oil seems to be below it but can't pinpoint the exact spot since it's hard to see back there. Will try to get a picture later
  5. ibcalm19
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Only thing behind there that could be leaking oil would be where the injector & jake brake wire go into the cylinder head. Was that checked?
  6. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Is it leaking around front cover and running to back down a crack? It happens
  7. cat13
    192
    60
    Jul 8, 2013
    Central FL
    I don't believe so but maybe. The block Is fairly dry till you get to back corner of the valve,rocker box, head. I can see ithe drip from the back corner but can't tell where from yet
  8. cat13
    192
    60
    Jul 8, 2013
    Central FL
    I think they replaced the harness but not sure. I'll have to pull the paperwork out and see
