C15 2006 rear main seal leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by SA1, Jul 26, 2019.
  1. SA1
    SA1 Bobtail Member
    11
    8
    Jul 25, 2019
    hi, i got a 2006 C15 engine with a leak coming from the rear of the engine looks like its the rear main seal. The engine has 26000 hours with 350,000 km (it was a vacuum truck before i got it). i wanted to get it fixed later in the winter. any products anyone might have used or knows about that helped to stop the leak for the time being.
    Thanks everyone
  3. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    No.......
    Save your money, put oil in it until you can take it down to fix it correctly.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    In my opinion, leak stoppers, for whatever leak, shouldn't be used at all. Except for maybe power steering as it's a system that's somewhat closed off from the rest of the engine. And if your replacing the pump, might as well do the hoses too.
    As a teen, I helped my uncle at his auto salvage yard. It's amazing at how those additives can clog weep holes and greatly reduce flow inside an engine.
    That said, I don't recall seeing anything of that nature in the oil system. Usually, it was the cooling system that had the issues.
    I did see a lot of engines that were screwed up by Slick 50. That crap turns to peanut butter.
    Again, my opinion.
  5. Jthauler
    Jthauler Bobtail Member
    Jul 26, 2019
    Could be expensive but do it right. Chances are it’s not only the rear main. Likely rear engine housing gasket needs to be changed too. When I got mine done at cat they put clutch, housing gasket, rear main seal, motor mounts, and main bearings since the pan has to come off too
    Diesel Dave Thanks this.
  6. SA1
    SA1 Bobtail Member
    11
    8
    Jul 25, 2019
    luckily had a deliver right in front of kenworth today. What are the chances right. I talked to the lead and he said same thing as everyone here and how the addictive might get clogged in other areas like RustyBolt said. Thanks again everyone
  7. Diesel Dave
    9,733
    33,346
    Jan 20, 2010
    Hesperia, Ca.
    Don’t forget the transmission cooler lines. They get brittle over the years.
    mtoo Thanks this.
  8. ichudov
    ichudov Heavy Load Member
    742
    642
    Mar 14, 2012
    Berkeley, IL
    How much oil do you need to add?
