C15 accert coolant diverter valve problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by E model Cat man, Jul 5, 2016.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,121
    May 19, 2011
    Have you checked the air to air and hump hoses, also check the bellows between turbos and cooler, if they crack (which they are known for) fuel mileage will suffer.
  3. Oscar the KW
    12,247
    28,121
    May 19, 2011
    You're also winding it up to high before shifting, it'll do nothing but eat fuel over 1600.
  4. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    If it's making 55psi of boost and suffering from poor fuel mileage verify the exhaust isn't plugged. Also you need to monitor readings on CAT ET to make sure readings are within spec. In order to achieve boost you need fuel so it makes sense both of these symptoms happened simultaneously.
  5. TeeJayW900
    TeeJayW900 Bobtail Member
    What wound up being your problem? Did u ever figure it out ? My 2005 c15 Avery is a acting the same way
  6. E model Cat man
    E model Cat man Light Load Member
    79
    72
    Jun 10, 2014
    Northern Maine
    It was a combonation of a high fuel temps around 185-190° from low fuel capacity at only 125gals full after wet system/split tank install, a really ####ty tec that had the overhead all over the place and had deleted the injection calibration codes from the ecm, etc...had overhead and ecm straitened out and added a fan cooled fuel cooler in the return line. Dropped fuel temps 50°+- and helped big time.
    Oxbow and SAR Thank this.
  7. Jtrejo
    Jtrejo Bobtail Member
    My mxs is running hot on water and oil temperature side popped some coolent hoses when replacing them found precooler was paying coolent not much but had some dried up changed out solenoid to devrtervalve and noticed it stays hot you can't touch it
  8. stuckinthemud
    stuckinthemud Medium Load Member
    620
    3,063
    Oct 20, 2013
    Thread is probably old and stale , last post was close to 4 years ago. You might ping one of posters who responded to the first post
    Oxbow Thanks this.
  9. W903B
    W903B Light Load Member
    80
    26
    Jun 5, 2016
    Did you found why it's burning hot?
