c15 acert low boost
Discussion in 'Peterbilt Forum' started by showtimenga, Aug 26, 2015.
  1. showtimenga
    showtimenga Bobtail Member
    21
    Apr 19, 2009
    douglas ga
    hello all.... i have a 06 c15 acert with low boost under hard pull its about 19 lbs havent found anything leaking all boots clamps cac all good but the las 2 manifold bolts are broke off with soapy water its shows leaking bad will that cause it to have low boost kinda thought being its the manifold it would be kinda like a out put of exhaust ... help plz thanks
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    yep!!..... also check your cac for leaks. you will have to plug both ends and pressurize with about 30lbs with a gauge to see if it leaks off.
  4. showtimenga
    21
    Apr 19, 2009
    douglas ga
    had cac cked and all the boots and bellows the only thing i cand find it the two manifold bolts end closest to front of the motor broke off...
  5. AModelCat
    165,007
    I would get those broken bolts replaced first. Air is lazy and it'll take the path of least resistance. Another thing that'll affect boost is the air filters. If they're getting dirty you won't be able to get enough air to build high boost. I would start with those and go from there.
  6. showtimenga
    21
    Apr 19, 2009
    douglas ga
    ya i will get it done wiych i was going to anyhow but was jusy wondering if thats my boost problem my air fileters a fleet filters about 2 weeks old.. lord hope that will fix it..
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    I'd have a good look at the high pressure turbo as well. Pop it off and inspect the fins and make sure it's spinning freely. Not a difficult task. Just time.
