C15 Acert oil in water
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Diesel Dan 92, Aug 5, 2017.
  1. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    It is tough to see in that picture but I believe that coolant line is coming from the bottom radiator hose, and is probably routed from there to a tranny cooler. I could be wrong though. A couple of my cats are set up like this with tranny coolers anyways.
    Oxbow Thanks this.
  3. AModelCat
    166,497
    Check transmission cooler. Some are oil to coolant.
    Oxbow Thanks this.
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    Yer right, looked closer and realized that.
    Oxbow Thanks this.
  5. Superhauler
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    NM, usally you get coolant in trans. Since the trans pump doesn't make that much pressure but not Impossible.
    jamespmack, Oxbow and AModelCat Thank this.
  6. AModelCat
    166,497
    Good to know. Didn't know transmission pump pressure was that low.
    Oxbow and Diesel Dan 92 Thank this.
  7. Diesel Dan 92
    Diesel Dan 92 Light Load Member
    137
    50
    Nov 27, 2015
    Thanks guys.
    I'm going to order an oil cooler and flush the coolant ASAP.
    I have to run until then. Good news is I am not putting many miles on doing this months route.
  8. Superhauler
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    Like the one post said. If your heater hoses look like they are sweating, your to late. You will need to replace all your coolant hoses before they discenagrate.
    Oxbow, Diesel Dan 92 and SAR Thank this.
  9. Diesel Dan 92
    137
    50
    Nov 27, 2015
    Will order heater hoses too. Thanks.
    Oxbow Thanks this.
  10. Superhauler
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    And radiator hoses.
  11. Heavyd
    Heavyd Road Train Member
    7,839
    6,295
    Feb 4, 2009
    It can take several flushes to get most of the oil residue out of the cooling system. It is very normal and common to see small amounts of oil show up in your coolant after a repair since it is pretty much impossible to get it totally out and perfectly clean. So don't panic if you see oil in your coolant afterwards. It shouldn't be a lot though.
