C15 acert oil leak help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by The Biggest Dawg, Dec 8, 2019.
  1. The Biggest Dawg
    The Biggest Dawg Light Load Member
    177
    99
    Oct 16, 2019
    [Location Not Found]
    Is this normal? What is that tube called?
    Oxbow Thanks this.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Thats the crank case breather on a 6nz and newer Cat and yea that’s pretty normal. How long where you parker there and was the engine idling?
  4. The Biggest Dawg
    177
    99
    Oct 16, 2019
    Parked for 18 hours. No idling. I drove it home about 500 miles let it cool down and parked.
    Oxbow Thanks this.
  5. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Install an oil catch can,it came from factory on my accert
    The Biggest Dawg Thanks this.
  6. Wheeljack
    Wheeljack Light Load Member
    105
    1,051
    Sep 16, 2019
    Normal. My acert does the same thing when I shut down at night and come back in morning.
    SAR, The Biggest Dawg and Oxbow Thank this.
  7. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    thats your blowby tube. sit in one spot long enough, you will have that. When your motor is wore out to the point you need a future overhaul, you will have a steady drip
  8. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    That's normal, I dont recall ever seeing a cat that didn't have a little blow by or a drip from the tube after sitting idling or not. My truck will mark its territory worse than that after idling for 10 minutes
  9. Chubby Fly
    569
    797
    Nov 25, 2019
    That’s for sure!
  10. 379exhd
    2,925
    3,153
    Jun 25, 2012
    Funny thing is Mississippi inspected me today I shut the truck off immediately. He noted an air leak from the balance port on the brake valve...well no ####ing #### ossifur that's what that valve is designed to do since you wouldn't let me release my brakes. Told him it was an o ring and I'd fix it at the loves...he never did say anything about the oil pan, or frame being covered in oil.
    My old b just likes to let people know where shes been. Come to think of it I'm not sure I've ever seen a b model that didn't leak a little...or a lot of oil if it wasnt washed weekly. My 3406E wasn't bad but this b model does like to leak about a gallon every 10k or so.
    Chubby Fly Thanks this.
  11. The Biggest Dawg
    177
    99
    Oct 16, 2019
    I just got this truck and it has 75k on a gold rebuild. Does anyone know where I can find the maintenance schedule for this engine? 04 or 05 acert
