C15 Acert Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RobTheMech1, Dec 26, 2021.
  1. RobTheMech1
    RobTheMech1 Bobtail Member
    11
    Apr 12, 2020
    Ive got a 06 Kenworth T2000 with a c15 Acert MXS engine code.
    I want to know if the muffler I have on this truck the original. Also is it a "cat" of some kind with a restriction or just a muffler.
  3. TrucknWrench
    TrucknWrench Bobtail Member
    Nov 16, 2021
    If it’s the factory muffler then yes it is a “cat” of some kind. I doubt if you can be sure without looking in one end or the other or finding a part number on it.
    RobTheMech1 Thanks this.
  4. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,827
    Dec 7, 2015
    OK
    It’s just a muffler likely original
    Oxbow, Pamela1990 and RobTheMech1 Thank this.
  5. Deezl Smoke
    Deezl Smoke Medium Load Member
    539
    356
    Feb 12, 2011
    Hillsboro Oregon
    06', just a muffler. Looking at the inlet piping, frame and fasteners, it MAY be original, but your truck would have to be very low miles. MXS is a keeper. Don't let that engine go. It's worth 5 times what the rest of the truck is worth.
  6. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    I agree it looks like a muffler given the Donaldson logo. Call KW for a price on the replacement, if you pass out from sticker shock you know it’s a Converter. You are in the year range where it could have one, or had one……
    black_dog106, Oxbow and Pamela1990 Thank this.
  7. AModelCat
    164,762
    Vast majority of folks I know put regular, flow-through mufflers on when they needed replacement.
    little cat 500 Thanks this.
  8. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    On a Mxs if that is the original muffler/catylist would be a catylist on it, they were made by Donaldson. I've never known anyone to put one back on one when they need replaced or get plugged up, new catylist is $4200+ or you can get a regular muffler for a couple hundred.
    Only way to know for sure what it is is to run the part number on it or look inside of it.
