C15 cat bubbles and pressure radiator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kenllah, Apr 29, 2021.
  1. Kenllah
    Kenllah Light Load Member
    226
    113
    Nov 17, 2017
    Immediate cooling system pressurizing on engine start. Blows coolant out of the radiator cap. Apparently engine lost coolant last year and was overheated. driver filled it with drinking water asap and kept going. Put a cooling system tester on it to check for exhaust gasses and it changed colors.
    Just pulled the head. All 6 cylinders exhaust valves cracked between valves. Possible head gasket blown as well. Looking for input on this. Not really sure what I'm looking at or checking for. 20210429_084210.jpg
  3. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    no possible about it head gasket is blown
    spsauerland and Kenllah Thank this.
  4. Kenllah
    226
    113
    Nov 17, 2017
    What about the cracks between exhaust valves? Showed photo to service manager and he said definitely head job? What should I be looking for on the sleeves, block and spacer plate. Nothing looks obviously damaged. Was looking for a break in the fire ring but I guess that isn't a necessity . 20210429_084332.jpg 20210429_084312.jpg
  5. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Liner protrusion is very important. Also if it has not had anything in it other than water for a long period of time you may have pits in your liners.
    Kenllah Thanks this.
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    More than likely your looking at a infame you gotta find out what your liner protrusion is before you just slap a head back on it
    Smellfunny and Kenllah Thank this.
  7. Kenllah
    226
    113
    Nov 17, 2017
    I'll print up a worksheet and go thru the numbers on it to see where we are at on liner protrusion.
  8. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    there is a thinner spacer plate if your not to low
  9. Kenllah
    226
    113
    Nov 17, 2017
    Little bit better photo and it becomes a lot clearer. 20210429_183601.jpg 20210429_183549.jpg
    On the rest of the cylinder fire rings you can see the gray gasket material forming a raised circle except between #4 and #5 cylinders where #4 blew out. Would anything else cause that but bad liner protrusion? Had 2 head bolts a bit on the rusty side between #5 and #6 cylinder on the passenger side.
  10. Kenllah
    226
    113
    Nov 17, 2017
    Zoom, zoom, zoom and there she is. The obvious... Screenshot_20210429-190744_Gallery.jpg
    So, what's the best way to clean a block with the liners still in? Just scrape everything into the coolant passages and slap it together before anyone notices? any tips appreciated
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,516
    6,570
    Aug 26, 2014
    Do everything you can to get all the trash to the outside of the engine. Heavy abrasive discs can get particales similar to sand in the crankcase. That can damage a lot of stuff.
    I have worked for some of the cheapest of cheap ##### at times. Experience is educational. If the head was hot enough to crack like that the liner O rings were most likely overheated a well.
    At a minimum pull the liners. Inspect them. If OK hone them and reinstall with new O rings. That is provided the pistons are in good condition. Do the ring lands check OK with a gauge?
    Replace the rings as you have them out but also because they may have lost tension.
    When you price all the individual parts you can probably buy a good aftermarket overhaul kit for less.
    Measure liner height before you take it apart. If it is wrong now new parts is not going to fix that.
