c15 consuming oil
Discussion in 'Ask An Owner Operator' started by -blitz-, Dec 31, 2020.
  1. -blitz-
    -blitz- Bobtail Member
    43
    17
    Apr 26, 2020
    hi guys,
    i don’t now if im posting in the right section.
    i have c15 accert 550 and it has 250k km after rebuild.
    i live in canada alberta and its very cold here right now. i had kept my truck running all night for few nights on idle at 1000rpm. in summer time i had to add one gallon of oil every 10000km and now i have started adding 2 which is not normal for cat. I asked the guy who rebuild my engine and he told me that it could be because of cold weather and the idling i did. also he said that cold weather and idling causes the pistons and pistons rings to shrink. he told me to run the engine hot and not to idle for winter and it should get normal. my question to the experts here is, do you guys think this will get normal and pistons will come back to its normal place with the sleeves or i will need to get new piston rings..
    thanks..
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Buy a ele. block heater and plug it in when your at home, they also have a ele. heater for batt. that wraps around them to keep them above 32 temp?
    -blitz- and blairandgretchen Thank this.
  4. -blitz-
    43
    17
    Apr 26, 2020
    yes i have just got a bunk heater and engine heater installed..
    thanks
  5. AModelCat
    165,533
    1000 RPM idle really isn't that high. I'd run it up around 1200-1250 myself.
    -blitz- Thanks this.
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    You need to get it hot l. 200 deg. Or higher. On a good hard pull. A few times. Idling above 1000rpm. If not you end up glazing (polishing) the liners and it will never cure itself. Hang a winterfront on it but don't completely block off the air flow when running down the road. Sitting still cover grill completely. Heat is a diesels friend !
    650cat425, razor1983, -blitz- and 2 others Thank this.
  7. -blitz-
    43
    17
    Apr 26, 2020
    thank you sir, i will try to run it hot and see if it makes a difference.. like you said..
    hopefully i haven’t done much bad to the liners.
    thanks again.
  8. joey8686
    joey8686 Light Load Member
    131
    155
    Jul 1, 2014
    How many kms do you go between oil changes? Any Cat or Cummins Ive had would use more oil once I got closer to the time for an oil change
  9. rollin coal
    rollin coal Road Train Member
    13,727
    28,294
    Mar 29, 2008
    TN
    I always bumped my CAT to 1,000 rpms when idling to keep the temps up. Oil consumption after a rebuild shouldn't happen. It happened with mine. Probably ring gaps aren't right. Who knows. CAT will say the oil consumption is "in spec" so good luck...
    Doealex and -blitz- Thank this.
  10. -blitz-
    43
    17
    Apr 26, 2020
    i do my oil changes around 18000 to 20000 km.
    already dumped two gallon and only 12000 km.
  11. abyliks
    abyliks Road Train Member
    4,170
    9,846
    May 2, 2010
    ludlow MA
    How low does it get? My uncles truck gets to the add mark after about 5k on an oil change, then it drops to about the width of your pinkey finger and stays there until about 15k when it’s due for a change, even if you add a gallon it goes right back to the same spot
    spsauerland, -blitz- and AModelCat Thank this.
