My truck has been running like it has a 4cyl in it. When loaded I drop down to 40mph or so. It’s drastically down on power.
I had a guy hook a computer up to it. He said it’s not reading boost and there’s a barometric code being thrown. He disconnected the boost sensor and then got a code for it, so he feels that sensor is working. Do you all have any suggestions on where to start to solve this issue? Is there a barometric sensor on the motor that could be bad that’s causing it to de-rate….would that do it? Could the boost sensor be bad even though it doesn’t throw a code for it when connected?
Please and thanks for your help.
Cat 15 3406e 1LW
C15 down on power!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gix1k, May 23, 2021.
Page 1 of 6
Coming here to learn too
yes there is a sep barometric sensor low on the block drivers side triangle plug
Gix1k Thanks this. -
When it fails does it cause this issue?
Interesting. Been having similar issues with the ACERT we have
I know it sounds stupid, but I would change out my fuel filter first and go from there. I've had clogged fuel filters do crazy things before. Good luck.
It doesn’t sound crazy…that’s been suggested, but these are fairly new. Like less than 2000 miles.shooter19802003 Thanks this.
Yeah, but if you got crap fuel and didn't know it. Who knows. However, it would be worth the $35 to me to find out.
I won’t rule that out. I’ll replace them along with the two sensors. 1 of the 4 hopefully solves the issue.Coffey, Shawn2130 and shooter19802003 Thank this.
Page 1 of 6
