C15 Engine fan, at what temperature does it come on?
Discussion in 'Ask An Owner Operator' started by AL617, Sep 25, 2022.
  1. AL617
    AL617 Bobtail Member
    7
    Mar 4, 2021
    What’s going on guys , I have a c15 mxs and my question is at what oil temp does the engine fan engages at?
  3. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    Not sure it really matters. Oil temp on the acert cats is a computer generated number based off water temp, engine load and such. I'm 98% sure of that. Don't believe me? Look in your oil pan for a temp sensor
    ProfessionalNoticer and Oxbow Thank this.
  4. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    The fan engagement is based on the engine coolant temperature.. engine oil temperature is Irrelevant
    cke Thanks this.
  5. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    IMHO accerts run too #### hot...normal op temp is approximately 195....ECM set to kick fan at 208 if memory serves....heads toast by 225
    cke Thanks this.
  6. cke
    cke Road Train Member
    6,174
    76,035
    Aug 4, 2013
    Colfax Wi
    My cat has a oil temp sensor.
  7. Lazer
    Lazer Road Train Member
    1,849
    2,983
    Jan 22, 2017
    Not sure on the acert’s, but on an ISM there is an oil pan sensor that feeds a gauge in the dash, and a sensor that feeds the ECM, that will trigger an engine shut-down if engine oil temp gets too high.
    Last Call and cke Thank this.
  8. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    Yeah what model cat?
    Think they all did up till acert
    cke and Oxbow Thank this.
  9. lester
    2,957
    8,086
    Jan 2, 2012
    NW, Iowa
    Yeah I'm sure. But somewhere along the line cat did away with the sensor. It's just a computer generated number based off other things. I don't understand why
    cke Thanks this.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,056
    5,480
    Mar 18, 2021
    St Malo mb
    I’d be more worried if oil ran too cool I don’t think a diesel could get oil hot enough to break down .. as long as oil pressure is fine at your operating temperature your fine.. cold oil doesn’t burn off moisture and it turn acidic..
    cke, Oxbow and ProfessionalNoticer Thank this.
  11. Ridgeline
    22,730
    123,542
    It doesn't trigger the fan, coolant temp only.
    Last Call, cke and Oxbow Thank this.
