C15 engine won’t turn over
Discussion in 'Ask An Owner Operator' started by Moephilly1, Feb 1, 2022.
  1. StayMovin
    StayMovin Bobtail Member
    Jan 29, 2022
    starter isnt getting enough amps. this will get worse as it gets colder. Thats why your motor cranks worse the more you try. if you can't test your batteries on your own. pull em and get yourself to a parts store that can. Try to spend the extra bucks on a battery with higher rating of cold cranking amps
    Moephilly1 Thanks this.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Don’t judge a book by its cover. Those wires can look fine on the outside and be all green and crusty on the inside.
    77fib77, Vampire, Shawn2130 and 3 others Thank this.
  4. SmallPackage
    5,831
    18,692
    Dec 20, 2019
    Marion Texas
    Sometimes on the Delco’s the big solenoid on the top of them will arch the contacts inside and burn a portion of them away. Was not uncommon to have to take the solenoid apart and clean, file, or grind/buff the contacts. Sometimes rotate them to a new side to work. They would cause starter motor to crank slow and then “lock up” as the bad contacts got hot. They would then stick until tapped with hammer to reset. That is why Delco began to recommend installing the extra “ford” type remote solenoid sometime in the 80’s.
    ProfessionalNoticer Thanks this.
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Also the power bar that's held on to the power terminal on starter and up to the sel. is held on with torks head small bolts that l have found to be louse and causes many starters to be changed out with the new style small ones?
    77fib77 Thanks this.
  6. Moephilly1
    Moephilly1 Light Load Member
    111
    35
    Oct 6, 2016
    Thanks guys I ended up push starting the truck and now it’s fine so far. I’m still going to change the starter and a couple other parts to be on the safe side.
  7. Ruben01
    Ruben01 Bobtail Member
    20
    9
    Feb 1, 2022
    Probably need a new starter
  8. Ruben01
    20
    9
    Feb 1, 2022
    Or might have the wires that go to the starter loose
    Moephilly1 and 77fib77 Thank this.
  9. snowwy
    snowwy Road Train Member
    20,619
    13,340
    Jul 6, 2009
    Now that it's running. Good time to check the charging system before shutting down.
  10. Moephilly1
    111
    35
    Oct 6, 2016
    That’s what I’m thinking because the starter might not be strong enough to turn the fly wheel quick enough for the engine to turn properly.
  11. snowwy
    20,619
    13,340
    Jul 6, 2009
    If the alternator isn't charging the batteries fully.
    The starter will struggle.
    If the batteries aren't functioning properly. The starter will struggle.
    If the battery cables are even the slightest loose. Or some corrosion. The starter will struggle.
    Did anyone mention the starter yet?
