C15 exhaust sleeve failures
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 1roadie, Jan 26, 2012.
  1. 1roadie
    1roadie Bobtail Member
    6
    5
    Jan 26, 2012
    So. Cal
    Anyone have info on the CAT exhaust sleeve failures? are they failing at the weld? what seems to be the cause for these failures, is it mainly due to the extreme exhaust temperatures and the thermal cycling they are exposed to?
    looking for how bad the problem is, so I can research best solutions without excessive cost of advanced alloys instead of 304 stainless.
  3. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Mine failed at the weld. Good clean break, turbos didn't like it though and neither did the checkbook.
    1roadie Thanks this.
  4. kalh7
    kalh7 Light Load Member
    186
    62
    Mar 28, 2007
    southern illinois
    had one that came loose. only noticed it when the turbos started making different noises and took it to the shop. tore up both turbos, cat paid the bill. got lucky was still under warranty.
  5. Jas
    Jas Medium Load Member
    Not the best solution but the most cost effective and the only one 100% guaranteed to not have a repeat failure is to leave the sleeves out completely.
  6. Jfaulk99
    2,914
    1,652
    May 16, 2009
    Couch
    I agree, I should have done that but though since it made it 400k before the first failure maybe the newer ones would last longer......or they should make a turbine wheel that will survive a high speed chunk of stainless.:biggrin_2559:
  7. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    Thats one clean burning motor! No soot anywhere, the EPA should be so proud.:biggrin_2559:
  8. kalh7
    186
    62
    Mar 28, 2007
    southern illinois
    here is what was left of mine.
  9. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    I worked at Freightliner and did the same truck twice, He brought it in for something else and I could hear the rattling of anouther failure, he was furious with me saying it was my fault, I called Cat and got him in earlier. He went in and they had a whole line of trucks everyone of them getting the same thing. He came right over and apologised. I loved those Acerts.
    I retired but in the neighborhood they are removing and re powering all the logging trucks that had the new Cats.
  10. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    Can you post the number of the places removing the Cats I am looking for one to power a glider I am going to have built.
    Jfaulk99 Thanks this.
  11. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,488
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    I would think that the repowering a truck over an exhaust sleeve seems a little excessive, especially when the gasket without the sleeve can be gotten from cat.
