C15 fan on continuous
Discussion in 'Trucks [ Eighteen Wheelers ]' started by HISPEED428, Mar 23, 2013.
  1. HISPEED428
    HISPEED428 Light Load Member
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    I've searched the forum and read everything I could find as to what could and can cause this problem. Replaced A/C hi-pressure switch, jumped the harness. Fan still on. Changed fan solenoid on firewall, didn't fix it either. Changed IAT sensor, fan still on. When I check voltage going to the fan solenoid I had 12.22volts while engine was running, it would spike to 13.45volts when engine would shut off and briefly open the solenoid which would then disengage the fan briefly. This started as an intermittent problem and has now become continuous. Could it be a bad coolant temp sensor??? How would I diagnose the sensor with my ohm meter??? Checked the fan override switch in my dash and seems to work fine. Any help and ideas appreciated. Engine is a NXS C15. Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,842
    6,297
    Feb 4, 2009
    Ok, lets start with just the fan clutch itself to make sure it is mechanically ok. If you apply shop air to the air line going to the fan, does the actual clutch disengage? If so, if you jump 12 volts to the fan solenoid, does the clutch disengage?
    HISPEED428 Thanks this.
  4. HISPEED428
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    Yes, the fan clutch disengages with shop air. No air leak at the fan clutch. The harness going to the fan solenoid has 12.22 volts when engine is running. At 12.22 volts the fan stay's engaged. When I turn the engine off, voltage at the harness spikes to 13.45 volts which energizes the solenoid to disengage the fan briefly. The fan's been on since I left Sheridan WY, drove across IH-90 all the way to Seattle WA, gross weight 130000lbs and not once did coolant temp go higher than 185deg's. I tried everything I could think of to create heat but the gauge never budged. I should also mention that the fan solenoid has air at the supply side. Thanks for your reply Heavyd.
  5. KrazyOn-Highways
    KrazyOn-Highways Bobtail Member
    24
    4
    Mar 22, 2013
    Did you recently change any config parameters?
  6. HISPEED428
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    Nope, nobody's been in the ecm...
  7. pop's
    pop's Light Load Member
    54
    16
    Feb 3, 2013
    Yulee FL.
    check the ground side. the sensors use the ground to control the fan switch.
  8. DDS
    DDS Medium Load Member
    519
    177
    May 20, 2008
    Toronto
    You need to recheck the A/C wiring, you may have jumped the switch, but if the wire is broken to the ecm, open is on. You can check this with cat et,
  9. Heavyd
    7,842
    6,297
    Feb 4, 2009
    Yep, still sounds like an a/c high pressure/wiring issue.
  10. HISPEED428
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    I'm not very good with diagnosing wiring and sensors. Would you mind explain in detail how to do this??? Thanks
  11. HISPEED428
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    Stopped in at Peterbilt in Surrey BC yesterday. I asked them if they could check with CAT ET. Nope, they were to busy. Asked if they could print the diagnostic tree for me so I could check everything. Nope, they couldn't do that either. Come back Tuesday they said, nope say's I, gotta be in Calgary by Monday. Both service managers had never worked on the floor. I'm thinkin it's got something to do with the A/C as well. Forgot to mention in prev post's that when my A/C condenser blew in December the problem went away. It was intermittent then but with no Freon in the system the fan worked normal. Got the A/C fixed in January and the fan worked fine for a coupla day's but then started acting up again. It just gradually became more frequent that the fan would cycle for no reason and now it's just on contiuous. Appreciate all the help guy's. Thanks
