C15 noise in motor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, Nov 27, 2020.
  1. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
  3. anthonyar4
    431
    92
    Jun 8, 2019
  4. Allinone777
    Allinone777 Bobtail Member
    11
    16
    Nov 2, 2020
    Check pulley belt tensioner
  5. anthonyar4
    431
    92
    Jun 8, 2019
    I don’t have one on this.
  6. anthonyar4
    431
    92
    Jun 8, 2019
    2004 western star 4900 c15 just has a bolt that is used to tighten it but that broke.
  7. anthonyar4
    431
    92
    Jun 8, 2019
    So I just un-bolt the bracket and lift it up to tighten.
  8. anthonyar4
    431
    92
    Jun 8, 2019
    I get up to the motor and it sounds fine.
  9. AModelCat
    165,064
    You sure there isn't a tensioner pulley on the passenger side of the truck? Last MBN I worked on had a tensioner pulley there. you had to loosen off the bolts and then slip a 1/2" drive ratchet into the square in the tensioner plate in order to tighten the belts.
    bzinger Thanks this.
  10. anthonyar4
    431
    92
    Jun 8, 2019
    No there isn’t. I was surprised too. Unless the guy took it off there isn’t one.
  11. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
    If you have the old style with the adjusting rod behind the bracket, then you’ll need a small jack. I use a scissor jack in between the pulleys.
