I recently bought a 2004 Peterbilt 387 Cat C15 After with 1.4 million miles. The engine has not been rebuilt and no major repairs. The truck sat a lot for two years, only running it to keep things moving.
When I bought it, it had a dead miss on #1 and#2 cylinders. The old injectors had a rusty film on them and the shop said that the springs were collapsed, causing the miss. Two reman injectors and all was well.
I bobtailed it a while back and has a loss of power, lots of white smoke out the stack and eventually it stopped running. After it sat a few minutes, it started up and I got home OK. I felt the top of the radiator and large tube going to the block. They were cold, not cool. Cold.
The next day I checked the coolant level in the reservoir and it was empty. No leaks out of the engine or radiator/heater core. The oil was changed recently and is still clean. It would appear that all the coolant went out the exhaust.
I know that this is going to be a pricey fix, but until I pop it open, I do not know what to expect. Cracked head or head gasket are the two things that came to mind. What my questions are, other than a shot gasket, what should I be looking for? Are there tests I can do to find the culprit?
This truck is not a working truck. It is my personal truck that I bought for myself as a retirement gift. I'll need a big truck to haul all the huge fish I will be catching!!
I do appreciate any and all help you guys/ gals have to offer.
BTW. I have the intentions of doing the work myself.
C15 Severe Coolant Loss
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by A5¢, Jan 24, 2018.
Page 1 of 15
Liner walk, they rock back and forth
peterbilt_2005 and Oxbow Thank this. -
Unfortunately Old Man is correct. Sorry for the bad news.
Head gasket blown due to liners sunk is my guess, count on an inframe. If that head has to come off, with 1.4 million, you will be overhauling it no matter what you find. It doesn't make any sense not to overhaul at that point.
adayrider, BUMBACLADWAR, Oldironfan and 6 others Thank this. -
^^^^^ Preliminary knowledge of the actual problem is irrelevant. Grape Ape hit the nail on the head. Not trying to be a smartazz. Just saying
A5¢, GrapeApe, SAR and 1 other person Thank this. -
That is about what I figured the diagnosis was going to be. I'll have to wait until spring when I can make a tarp shelter. Wisconsin winter is a poor time to be working outside!
Thank you everyone for your help. Any suggestions for a good manual?bigguns Thanks this. -
Make absolutely sure you get the liner protrusion right. Most important part of the rebuild, it makes the head gasket last.
BUMBACLADWAR, A5¢, bigguns and 1 other person Thank this. -
I believe that is what has got me to where I am right now. I will know more when I pop the top off and see what gremlins are there. Hopefully, the head and the block will be flat.
Page 1 of 15
