Just got my truck back from an inframe. It runs better than ever before the only thing is, my water temp is acting strange... On flats where the temp would normally run 188* it will just randomly go from 188* up to 194* and bounce down to 186* then up to 192* over the course of a minute or so, for no good reason. It used to hold steady at any given temp, and any rise in temp was predictable on hills, steep grades, etc. And for some reason I can turn the fan on and it will never pull down to 186* like it used to always do. For whatever reason the fan will only pull it down to 192*. These temps are from CAT information display. My regular gauge in the dash the needle shows to be a little bit hotter than the 180* mark where it used to always sit and again the fan won't pull that down to 180*.
Don't have a digital readout of oil temp on CAT ID but on the gauge my oil temp normally always rode at "180*" The oil temp will hold steady there for the most part but sometimes in hills I notice it appears to rise about 5 or maybe 10*, not very much at all (not enough to really bother me a whole lot) and the only way to get that back down to 180 is with the engine fan. This is also "out of the norm" for my engine but I figure as long as oil temp is well below 200* it's nothing to worry about. I trust my oil temp gauge is failry accurate - at the very least it's not erratic. The water temp is driving me crazy even though I don't think it is running hot. And I also don't believe the actual coolant temp inside the motor is really erratic like the gauge is showing. Is it a sending unit that tells what the water temp is? Where is that at and how can I check it? Other than this everything is good with the inframe I'm really pleased with it.
C15 - water temp erratic - what could it be?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, Aug 17, 2012.
Page 1 of 3
The rise and fall in water temps, sounds like thermostats opening and closing. Did they perhaps replace them when the inframe was done? Also remember after an inframe everything is running a bit tighter.
Magoo1968 and rollin coal Thank this. -
I sort of figured the tighter tolerances could be a possible/logical explanation on the oil temp. Since it's not erratic and not TOO high I am ok with it..
They did put a brand new water pump on it - so I'm guessing they also put new stats in as well - CAT did the inframe.. Like I say it does this in the flats when I'm not really accellorating and maybe cruising along at 10psi boost or so. It will sometimes hold steady at 192* for a little while and then for no reason bump up to 194*. It might stay there for a little while or it might bounce down to 188* then 192* or whatever. It never holds constant for long and there seems to be no reason for it based on how I know my motor used to behave...Last edited: Aug 17, 2012
It could be a sending unit, my accert has more than one sending unit. I think one for the gauge and one for the computer. If yours is the same way then I would say you have a thermostat acting up or there is possibly air in the system.
For a start I'd say check the sender unit. Verify that you get a true reading. Secondly check for good connections on the unit itself. A thermostat will give you a more gradual rise and fall. Just to confirm what Oscar said.
Ok, where are the senders located? I suspected maybe the connections might be loose but don't know where they are. And Oscar you are correct there are two temp sensors, 1 for CAT info display, and a separate 1 for the gauge. I remember some general conversation about different things, water temps was one thing discussed - how accurate was the gauge versus CAT ID - and was told they have separate sensors. Now where exactly they are, I wish I had asked lol. Thanks guys, hopefully it's something simple. One more thing, pretty sure most if not all of the air is purged out, I'll check the water here shortly, but it's got 13 gallons in the system. Thanks for the tips..
My fuel gauge would do this, as posted about check the sensors, senders and all that. As for the fan, I'd have the on/off clutch replaced.
It should be on the thermostat housing. Check under the A/C bracket from the front of the motor. You should be able to trace the wires from the back of the motor to the sender unit.
mine was up behind the altenator u have 2 sensors there one for gauge one for fan .the gauge on a t600 is same as oil pressure behind. i swapped wiring behind when i wanted to see if it was gauge or sending unit to find a issue i had with loose connection
usualy if its a sensor failing or wiring the gauge will not work or go hard around sounds like thermostats to me but the rum im drinking could blurr my judgement
Page 1 of 3
