C18 Head on a C15 Acert
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by DEVINKLUG301, Jan 31, 2022.
  1. DEVINKLUG301
    DEVINKLUG301 Bobtail Member
    14
    9
    Jan 31, 2022
    I bought a 2007 379 with a C15 Acert. Looked to have a new head on it. Turns out its got a C-18 head on it which probably is why it runs like a dog on the top end. I'm guessing the head probably just has stiffer springs. I wondering if it needs to have a C18 cam or if a C15 cam will work. Also will the injectors work with that as well. I'm guessing it just needs some tuning to be getting enough fuel to run good. The injectors are 2490709. Any help would be appreciated, Thanks
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
  4. DEVINKLUG301
    14
    9
    Jan 31, 2022
    so the internals are the same aswell?
  5. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    I'm curious how you determined it was a 18 liter head? Cause yeah I was pretty sure they were all the same too.
    Doubt anything else is different either.
    Diesel Dave Thanks this.
  6. DEVINKLUG301
    14
    9
    Jan 31, 2022
    I says C-18 right on it
  7. pushbroom
    pushbroom Road Train Member
    1,791
    7,403
    Sep 1, 2012
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Says C18 on it were ?
  9. DEVINKLUG301
    14
    9
    Jan 31, 2022
    So when i bought the truck the ecm as bad so i had cat get me a new one and turn it up to 550 from 475. But the think climbs a hill like its got 250hp so I thought maybe because it has a C18 head maybe the springs are a bit stiffer and if it has a 15 cam maybe its having issues there. And then the 550hp tune they uploaded to the ecm is not working how it should. unnamed.jpg
  10. DEVINKLUG301
    14
    9
    Jan 31, 2022
    bottom side of the head next to the air compressor
  11. AModelCat
    164,924
    What difference would stiffer valve springs make? The cam pushes them open exactly the same regardless if they're 40 lb springs or 300 lb springs.
    (I pulled those numbers out of my hat but you get the idea)
    Last Call and Diesel Dave Thank this.
