C18 specs for heavy haul
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tnc110, Mar 14, 2018.
  1. tnc110
    tnc110 Light Load Member
    135
    81
    May 22, 2016
    I'm going to order a 389 heavy haul glider. I'm pretty well set on having a c18 built
    Looking to be 900hp plus. I'm looking for someone that has gone down this road or recommendations for someone who is familiar with the c18.
  3. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Not familiar on the c18 but I'm gonna guess that's fun to drive empty and has a small drinking problem
  4. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    I don't think you will be happy with it. A c-18 is a 3406-e or c-15 block with a c-18 crank and liner packs. The c-18 crank has a stroke of 7.2 compared to a-cert and c-16 6.75 stroke. The liners are thinner. There is alot of side throw force with the c-18 crank. You can make as much power with an acert crank and other parts and have a very dependable engine. The few who have done it have disappeared or you never hear about them anymore.
    Cat sdp, wore out, Oxbow and 3 others Thank this.
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Can you put a c16 crank in an e model? I can't find an e model 15.8 crank anywhere
    wore out and Oxbow Thank this.
  6. tnc110
    135
    81
    May 22, 2016
    I talked to a guy today that supplies parts for a guy that has several c18s. Said guy really likes them. I talked to another guy that has done several... said he hasn't heard back from any of the new owners... usually no news is good news! I've got a name of a guy that has one, i need to call and chat with him. His is putting down 1300 at the crank. This is a working truck.
  7. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Yep.
    wore out, Oxbow and SAR Thank this.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
  9. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Well not sure if that's a good thing for me to know
    wore out Thanks this.
  10. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    I'm not sure about the c18 buy when I rebuilt my c15 a guy mentioned a industrial or heavy haul kit instead of mine so I asked cat. Cat said my truck came with the normal rebuild kit but if I wanted I could order the heavy haul kit (Or industrial....cant remember what they called it) they told me it was built heavier, 1 piece pistons or some crap. They said it would hold up to the power and abuse of the heavy loads way better but it is louder.
    SAR and Oxbow Thank this.
  11. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    with a C18 it will need significant cooling system capacity if your ambient temps aren't sub 25 deg C
    Currently cat will not sell a 5.7 liner to a C18 serial number, only way to get one is quote a C32 serial number on the order.
    they are cracking around the bottom seal area putting oil into the cooling system and causing no ended confusion and issues.
    and angry NXS Acert at 16:1 will make more than enough
