CA Legal
Discussion in 'Flatbed Trucking Forum' started by cgilliland, Mar 28, 2020.
  1. cgilliland
    cgilliland Medium Load Member
    321
    744
    Mar 13, 2017
    I am a little confused. I see the 53' with the rear slider they say are CA legal with the slide closed to tandem. i get that. but it seems to be a 53' spread with 5' overhand off the back is about the same as a 48 fixed spread. So are the 48 fixed spread also not CA legal unless they have a rear slide which most dont?
    truckdriver31 Thanks this.
  3. singlescrewshaker
    4,868
    42,606
    Dec 31, 2017
    Little Havana, FL
    48' or shorter wagons are exempt from kpra (kingpin rear axle) laws. They are fine everywhere..
    To run a 53' fix spread in the Commie you'd need like a 36" pin setting & 10' of tail sticking past the last trailer axle..
    You might be able to buy a kingpin permit.? Not sure, but you can get one in FL..
  4. cgilliland
    321
    744
    Mar 13, 2017
  5. Espressolane
    18,690
    117,154
    53 foot trailer is subject to the KPRA rules, makes no difference if flat, step or van. This is why you see 53ft flatbeds with lots of rear overhang.
    A 48ft trailer with a spread is exempts from KPRA. Tandems are not.
  6. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Wrong on that last sentence.
  7. Buc
    Buc Medium Load Member
    392
    726
    Nov 17, 2012
    My fleet utilizes 53' flats (and some 53' steps) with the rear most axle set back about two foot from the rear. (I'm still trying to ascertain the necessity for a 53' spread to have axles set that far back vs the placement of a normal 48' spread--Jordan Carriers' newer trailers are set up that way, too.) Anyway, we have one simple rule:
    "Cali and Canada...close 'em up."
    That way we'll have nothing to worry about.
  8. Espressolane
    18,690
    117,154
    No, not wrong. In California, any trailer running a tandem axle, is regulated to maximum of 40ft KPRA.
    They also have a minimum of 38ft KPRA.
    Single axle trailer is max of 38ft KPRA.
    Pups are excluded due to trailer length restrictions.
    Subject to weight
  9. singlescrewshaker
    4,868
    42,606
    Dec 31, 2017
    Little Havana, FL
  10. Espressolane
    18,690
    117,154
    The key is, 48 foot or less AND 10’1” spread.
    Once you go to a tandem, then the 40’ KPRA regulation takes over.
    When you go to a 53, flat, step or box, the 40’ KPRA regulation applies. That is even if you have a 10’ spread.
    They make it a bit convoluted. No doubt.
    singlescrewshaker Thanks this.
  11. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    Vehicle Lengths | Caltrans
    Scroll down and look at exceptions for STAA vehicles. 48 feet, no mention of tandems vs spread.
    kylefitzy and singlescrewshaker Thank this.
