Cab & Chassis Road Ready
Discussion in 'Expediter and Hot Shot Trucking Forum' started by ltlmore, Oct 23, 2020.
  1. ltlmore
    ltlmore Light Load Member
    62
    26
    Jul 24, 2018
    Dayton, Ohio
    Does anyone have information on what all needs to be done to get this kind of set up going? Prices & places to get it done? I have read where you have to have fenders installed as well as mud flaps I think. And then there is the goose ball hitch installed some way. Ram shows you can order a 52gal. & 22gal. fuel tanks, so maybe an auxiliary tank wouldn't be need but an extra tool box would probably be great.
    Trucking Jobs in 30 seconds
  3. 24kHotshot
    24kHotshot Medium Load Member
    635
    558
    Feb 19, 2019
    New York
    I have the 52 and 22 fuel tanks. Had my upfit done at hitchcrafters. $3k, 2 tool boxes.
    Btw, truck with upgraded 19.5 steel wheels, full tanks and all kit is almost 10k lbs
    singlescrewshaker and Lite bug Thank this.
  4. ltlmore
    62
    26
    Jul 24, 2018
    Dayton, Ohio
    That is a nice clean set up. I think I have seen where you run cars. I like that most (if not all) car haulers are a 5th wheel set up instead of gooseneck ball. I would think the 5th wheel set up would help a lot with sway & trailer frame flex.
  5. 24kHotshot
    635
    558
    Feb 19, 2019
    New York
    Single pivot 5th wheels are the only safe ones to use for car hauling if you ask me. No lean in the trailer means less chance of a flip. Fifth wheels that are dual pivot not only flip but flip the trucks themselves. A gooseneck will at least release on a far enough lean and disconnect from the truck. Dual pivot fifth wheels are for RVs only.
  6. crocky
    crocky Road Train Member
    1,525
    1,261
    Jun 28, 2017
    I don't think the DOT requires fenders so far as I know so long as you have mudflaps. Semi's aren't required to have fenders just mudflaps. Obviously, fenders will keep things cleaner.
    I just outfitted my F550 myself and I didn't put fenders on it yet, I'm just running a temp mudflap set up because I will be building out some actual fenders & frame catwalks.
  7. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,745
    5,703
    Mar 19, 2018
    Nashville
    You have a CDL?
  • Draft saved Draft deleted
