Cab heat
Discussion in 'Volvo Forum' started by shim2000, Jan 25, 2021.
  1. shim2000
    shim2000 Bobtail Member
    24
    Cab heat gets hot as I climb hills, goes cool down hill, flat road. Thermostat or??
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    The truck is running at a higher temperature as you climb the hills. You're heat control valve is more than likely not operating properly so letting more heat come through the vents. My guess anyway.
  4. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    probably thermostat
    KB3MMX Thanks this.
  5. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    Is the coolant level low?
    Check to see if coolant is coming out of the water pump weep hole.:dontknow:
  6. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Im with Nas here....probably thermostat.
  7. shim2000
    24
    Supposably the shop looked at it I don't know if they changed the thermostat or not but they said the engine fan is continuously spinning, which is not allowing the engine to get up to normal temp and they can't figure it out so off to the dealer it goes!!
  8. 86scotty
    86scotty Road Train Member
    4,741
    13,013
    Aug 27, 2017
    Appalachia
