Cab leveling valve dumps air when I turn of my truck.
Discussion in 'Ask An Owner Operator' started by Ikamob01, Feb 2, 2023.
  1. Ikamob01
    Ikamob01 Medium Load Member
    314
    195
    Dec 4, 2021
    Cab leveling valve dumps air when I turn of my truck. Is it a bad leveling valve? First I thought it was the cab airbag or shocks. I replace them but issue persist. Sometimes when I get of my truck I will hear a little bite hissing sound.
    Any help will do it.
  3. Lazer
    Lazer Road Train Member
    1,854
    2,994
    Jan 22, 2017
    What model truck? Does this happen immediately after turn the key?
  4. Ikamob01
    314
    195
    Dec 4, 2021
    International prostar. It happens overnight. When I wake up the leveling valve will be all the way down with deflated bags.
  5. AModelCat
    166,503
    What's your air pressure at after its sat overnight? If the tanks are empty or very low then its leaking out somewhere on the truck.
  6. Ikamob01
    314
    195
    Dec 4, 2021
  7. AModelCat
    166,503
    You've got an air leak somewhere on the truck. All trucks I've seen have a pressure protection valve and once reservoir pressure drops below somewhere around 75 PSI or so, it no longer allows air to flow to accessories like suspension, cab, seat etc.
    stwik, Siinman, Dino soar and 2 others Thank this.
  8. Long FLD
    Long FLD Road Train Member
    13,447
    57,132
    Mar 4, 2015
    Take a spray bottle of soapy water and get under your truck. Unless you can already confirm the leak is at the cab bags or leveling valve. Even if your air is leaking someplace else your cab will be dumped when your tanks are empty.
  9. AModelCat
    166,503
    I'm thinking he might find 2 leaks. If it was just from the cab suspension then the air reservoirs would maintain pressure once the pressure protection valve closed off.
    Siinman, Dino soar and Rideandrepair Thank this.
  10. Ikamob01
    314
    195
    Dec 4, 2021
    When I turn of the truck I hear a little bit leaks from the valve. Sometimes when I get out the truck it beeps air..
  11. Long FLD
    13,447
    57,132
    Mar 4, 2015
    If you hear a small bit of air when you get out and then it stops that’s just the cab leveling itself because you removed your weight from the cab.
    Vampire, stwik, Siinman and 3 others Thank this.
