Calgary----San Francisco
Discussion in 'Canadian Truckers Forum' started by tvc15, Jan 5, 2011.
  1. tvc15
    tvc15 Bobtail Member
    Canada
    I have been asked to run a load From Calgary to San Francisco. Any advice or recomendations from experienced members would be much appreciated. re: routing, road conditions, best truck stops etc. Thank you in advance.:biggrin_25514:
  3. Trade up
    Trade up Light Load Member
    156
    86
    Nov 11, 2010
    Toronto.Ontario
    Straight across 1 then down 5. The weather should be fairly mild with the exception of snow in the mountains of Northern California crossing in from Oregon.
    This time of year can be dicey through Idaho/Montana,so I would avoid that route.
    That would be my summer time route,very nice scenery.
    As for road conditions,keep your CB on and you'll find that when the conditions get harry that chatter picks up and drivers keep each other pretty well informed.
    You will NEED chains to enter California,without them in the truck you will incur a fine. Hopefully you already have them.
    As for truck stops there are enough along 5 that you won't need to worry about feuling or getting stuck in a dive truck stop.
    Good luck.
  4. Flying Finn
    Flying Finn Heavy Load Member
    972
    558
    Jun 22, 2010
    Ontario, Canada
    You NEED chains on #1, and #5 as well in AB/BC. Any high mountain pass can change in a blink of an eye. Take it easy and be safe. It is all winding road through the mountains so if you want to go slow then DO IT.
  5. Beer Runner
    Beer Runner Medium Load Member
    544
    227
    Nov 2, 2010
    Canada
    The way I always run it is. Calgary take 2 south, 3 west, 3/95 south, then 95 south to the I-90. West on I-90 south on 395 to I-84. West on I-84 to I-5, then south to California. If you run this route you probably won't have to chain up at all. If you take the #1 to Vancouver then south on the I-5 it will take you longer and you will most likely have to chain up along the route. Like I said I run this all the time.
    Check the chain-up status here. http://www.th.gov.bc.ca/roadreports/chains/chains.asp
  6. mgfg
    mgfg Road Train Member
    1,753
    626
    Mar 29, 2010
    Funny, I thought the route to Vancouver and south was way OOR also but not being a big left cost runner I wasn't sure what the better way was.
  7. Flying Finn
    972
    558
    Jun 22, 2010
    Ontario, Canada
    Good plan BR. To the OP, just remember that even if you don't have to chain up you still need to have chains on you. So far I've not had to chain up in BC yet. Just lucky so far.
  8. FLATBED
    FLATBED Road Train Member
    Check this out to give you an idea of routing and under DRIVERS TOOLBOX gives you links for weather & road conditions and you can get a list of truckstops for each state / province
    http://www.truckmiles.com/
  9. KenworthComeUp
    KenworthComeUp Bobtail Member
    44
    4
    Jan 2, 2011
    Coquitlam, BC
    :biggrin_25520:What company do you drive for btw. I am going to Mountain Driving School soon in Castlegar and would love to be given routes like this one. Thanks and tc.
  10. Beer Runner
    544
    227
    Nov 2, 2010
    Canada
    Bison until the 24th. But most companies will let you plan your own route. Years of experience will tell you how to run the rockpile, and what roads to take or not to take. Like in BC between Blue River and Valemount, you know they don't own a snow plow, and the road will always be ####ty in the winter. You get to know where the problem spots are after you do it for a few years.
    If the coke is a mess, run the canyon. And so on. It's only one hour longer, but saves you time.
