Whats the deal with Cali legal trailer i read it must be 40ft from the king pin to the center of the rear axle i run a 48ft double drop trailer and you have a double drop to haul this load can you get a permit or do thay really make a big deal about it just wanted to get some info before i take the load
Cali legal trailers
Discussion in 'Ask An Owner Operator' started by BAYOU, Oct 4, 2010.
Here is the link to the CA truck guidelines.
basically STAA roads 48' trailers no restriction.
CA advisory roads 40' kingpin to rear axle.
see the map in the link for which roads are which
http://www.dot.ca.gov/hq/traffops/trucks/truckmap/truck-legend.pdf -
Sorry follow this link for the map
http://www.dot.ca.gov/hq/traffops/trucks/truckmap/ -
Ok im lost now
No need to be lost. Take the load & forget about it. You aren't pulling a 53' trailer, so you really don't need to be concerned about the California Bridge Law
48 ft is exempt from the kingpin rule but if you have a flip axle and put it down good luck!!
A 48' DD is legal in CA with or with out a permit load. Flip axles are not legal for any reason. (per CA oversize permit office) A 53' DD can be permited if you jump thru hoops and cross your toes. Permiting a 53' as explain to me: You haul the load too the CA border, call an inspecter who will bring out portable scales and weigh each axle, and check every thing else. If all is within specs your issued a CA certified # that will be used on all future permit orders. If your trl won't pass no entry is allowed. However that 53' is not legal when empty. Trucks must be certified also.
So the law is for 53ft trailers only? so you can run a 48ft step deck also and be legal
Not on all roads.
As an example you could not take a 48' trailer with more than 40' king pin to rear axle to Ft bragg or Eureka as they are on Non-STAA roads.
So it depends on where the load picks up or delivers. -
Also some roads in CA have a 65' limit from front bumper to back bumper. On these roads a 48' trl may not work.
