Cam Shaft Gear Stuck
Discussion in 'International Forum' started by eng.moh.4u, Nov 16, 2018.
  1. eng.moh.4u
    eng.moh.4u Bobtail Member
    40
    4
    Jan 13, 2017
    In my DT570 engine I tried to remove the camshaft gear to replace the rear half front cover. I used a puller many times but the puller always slip from the two holes. Is there any way to remove this gear?
    If not and I have to remove the camshaft assembly is there any parts that should be dismantled to do this?
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Its a special puller. If your puller keeps slipping out, it is worn out. You can remove the whole cam, but the head and valve train has to come off first.
    eng.moh.4u Thanks this.
