Camera and speeding
Discussion in 'Experienced Truckers' Advice' started by Weepee, Apr 8, 2016.
  1. Weepee
    Weepee Bobtail Member
    With cameras inside the detect if you are speedig?
  3. Blackshack46
    Blackshack46 Road Train Member
    What? Elaborate more on the other day and time for you and your family????
    scythe08 Thanks this.
  4. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    Are you asking if a company has driver facing cameras inside will they detect if you are speeding? It doesn't matter. That company already is tracking your speed on the EOBR. Many companies with EOBR's already track if you go faster than the maximum allowed speed, whether you take a turn too fast, or have a hard braking event.
    I would think that with the addition of outward looking and driver facing cameras they could also note your speed compared with the posted speed limit. Some truck specific dash cams that you can buy in a truck stop can also include your speed, so that's something to think about for any driver that wants to upload YouTube videos.
    Moosetek13 and Starboyjim Thank this.
  5. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Can't imagine it's not clearly visible on the video.
    Unless it's embedded in the file only.
    My $200 Dashcam does both.
    Moosetek13 and Lepton1 Thank this.
  6. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,185
    May 12, 2012
    SouthEast Alabama
    This is my guess and I may be wrong, but it sounds good.
    If you have a forward facing camera (company-supplied or your own), your speed can be determined by an expert witness in court. It would seem to me the expert would know the length of the dotted line, use your video to calculate how long it took you to get from one dotted line to the next, then convert that calculation to speed.
    If you have a qualcomm, your company can certainly set speed (over speed and excessive over speed), idle (over idle), and rpm (over rpm) parameters and be able to see those numbers, at least as a percentage of how much you are doing each.
    If your truck is equipped with an ECM, my guess would be anyone who can access the ECM can see your numbers.
    Can your company see your speed in real-time? Not sure about that, but at the very least, all it would take is a couple of mouse clicks to find out your most recent numbers.
    Welcome to Big Brother's world. He is watching, he is always watching. With virtually everyone and their sister having cellphones with video-recording capability, businesses having cameras viewing the streets and even interstates installing video cameras to monitor traffic, you can assume you are being recorded when you are in public.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,988
    19,047
    Nov 1, 2010
    Burnsville, MN
    I've seen readouts from our (Swift) Qualcom, and nothing to do with a camera.
    They can be sure of what speed I am running at any given moment, down to at least a few seconds.
    There is a running log that they will go to if something happens, or any time they want to check on you.
    88 Alpha is also correct that a forward facing camera can be used to get a very accurate estimate of your speed based on the lines. The lines are a certain distance apart, and the camera is running at a precise speed.
    It is some very simple math.
    88 Alpha Thanks this.
  8. Moosetek13
    14,988
    19,047
    Nov 1, 2010
    Burnsville, MN
    55.24 mph.
    Down to 100th of a second.
