Can a 400HP truck carry 35K 53ft van load on steep grade easily?
Discussion in 'Experienced Truckers' Advice' started by alemiss, Oct 16, 2022.
  1. alemiss
    alemiss Bobtail Member
    25
    14
    Oct 16, 2022
    I read everywhere that Horse Power doesn't matter, it's torque and gear ratio that matter.
    I have a Freightliner DD15 455HP, 13spd, 3.08 rear ratio (I am not the driver, I'm the owner).
    (Edited after I saw a comment by another user @W923 )
    Now I am looking to buy a 400HP with cummins engine.
    Will a 400hp, DD15 or Cummins of the same torque perform just the same on flat terrain as well as hill? What difference will I notice from the 455hp?
    Chieftains Thanks this.
  3. alemiss
    25
    14
    Oct 16, 2022
  4. AModelCat
    166,504
    Back in the day they hauled those same weights with 300 hp. Just wasn't quite as fast going up.
    Don't worry about it, just drive it.
  5. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    608
    Nov 11, 2010
    Wyoming
    The world was built the first time with 220 Cummins and old Mack's. Like @AModelCat said I wouldn't worry about it
  6. alemiss
    25
    14
    Oct 16, 2022
    Thank you. Yes, I understand what you mean. But since I have a choice to buy higher HP, I am trying to understand the concept before I do and regret it later. There is this walmart truck 400hp Cummins ISX15 with 2.47 ratio. I want to buy it but I'm afraid it may not perform going up hills in some areas like Pensylvannia or sometime W Virginia.
    You think that concern is overblown? Thanks
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,065
    Nov 18, 2014
    Land of local
    You certainly won't be the first one up the hill but it'll do the job just fine. But if it was me I'd go for the higher HP one
  8. Oxbow
    Oxbow Road Train Member
    13,985
    146,150
    Nov 24, 2015
    I can't address your specific concern, but as a general rule I don't think you will realize any savings from running less horsepower in the hills.
    Good to see you here @Caterpillar Cowboy !
  9. Geekonthestreet
    Geekonthestreet Medium Load Member
    344
    587
    Jun 27, 2021
    Chicago
    Derating the engine isn’t worth the trouble. It might save you 0.1 MPG if any, but you’ll lose drivers and eat that money on training costs and insurance claims.
    Bean Jr. Thanks this.
  10. alemiss
    25
    14
    Oct 16, 2022
    Thanks.
    Derating? I am not sure what you mean. Does a lower HP engine derate more than a higher hp? I am not quite sure why you brought up deration here. Please elaborate. Thank you.
  11. Geekonthestreet
    344
    587
    Jun 27, 2021
    Chicago
    Oh I worked for a mega like most people here and they’d throttle the engines. If you work in the east like around PA I wouldn’t go anything under the horsepower of the truck you currently own. A DD15 with a full load will slow to around 40mph on a lot of the hills in PA. I can go look at the exact horsepower of my truck but a DD13 is for plains like the midwest. And for day cabs. Not enough engine for OTR.
    I run fully loaded tanker.
    alemiss Thanks this.
