Can DDEC a 5 head bolt onto a DDEC 6 block?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rbrauns, May 1, 2020.
  1. rbrauns
    rbrauns Light Load Member
    164
    56
    Dec 7, 2014
    So, after 4 months of battling 4.5 mpg with my 2008 Cascadia, I'm getting desperate for more miles per gallon.
    DDEC 6 has been inframed, overhead ran twice, new reman head, all new sensors and engine wiring harnesses. Although most of the random codes are now gone AND my engine runs pretty smooth, I can't get this engine to get better fuel economy.
    The truck has been reliable but I'm at the end of my rope chasing fuel economy. 3.90 gearing and Eaton 13 speed. I'm running at 1450 rpm @ 64 mph.
    I've posted and read on this forum that the DDEC 5 is vastly superior to the DDEC 6.
    Apparently the DDEC 5 is even capable of 7.5 npg whereas my DDEC 6 might manage 6.5 at best. I'm currently getting 5 and that's with my APU finally working and summer fuel blend AND more repair bills than my truck is actually worth !!
    The only things left to do are the injectors, injector wiring harness and the turbo. The turbo actuator has been checked twice. No issues.
    SO. I'm seriously considering buying a reman DDEC 5 head and using N2 injectors instead of the problematic E3 injectors.
    I'm pretty sure that the oil and water holes will line up but I know that the DDEC 5 fuel return line exits at the back of the head whereas the DDEC 6 fuel return line exits at the left rear of the head. The shop I want to use can deal with that.
    Will the compression ratio change at all using a DDEC 5 head?
    Will the N2 injectors hit the top of the pistons?
    I know that the N2 injectors have 2 pin connectors but the E3 injectors have a 4 pin connector.
    Does anyone know why the E3 injectors have 2 extra pins?
    If all I need is a custom injector wiring harness, then I'll get one made.
    Does anyone know why this won't work? Quality Truck maybe Benjamin 260_6?
  3. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    dd5 has n3 injectors you need to have a delete with a good tune the 3.90 rears prob not helping
  4. rbrauns
    164
    56
    Dec 7, 2014
    Thanks for responding to me. Thanks for the head's up re the N3 injectors. A few people have told me that a good tune will help but I'm not sure that the DDEC 6 will ever get 7 mpg hence the idea of swapping heads.
  5. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Delete and tune your 6. Only way you'll get better mpg. Head swap is just barking up the wrong tree.
  6. QUALITYTRUCK
    1,821
    1,788
    Jun 14, 2009
    romulus,mi
    Don't bother guys. I have tried to tell this gentleman the same thing over numerous posts and pm's. He is very polite and always thanks for time. He has an idea in his head that is eating at him and until he finds someone to tell him that it is a good idea to go ahead with it he is going to chip away here. If all engine parts are in proper working order, tune needs to be addressed. I see bad tunes at least once a week.......
    spsauerland, pushbroom and swaan Thank this.
  7. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Tunes need to he addressed is an understatement on that engine.
  8. rbrauns
    164
    56
    Dec 7, 2014
    @QUALITYTRUCK. I do thank you but I finally understand that I need a good tune.
    In numerous posts, I read that the DDEC 5 is a better engine so that's the root cause of my fixation.
  9. rbrauns
    164
    56
    Dec 7, 2014
    Wait. I am not wasting everyone's time.
    My tuner, the injector guy and this forum all told me that the DDEC 5 was a better engine. Before I buy a new set of E3 injectors and get a proper tune done, I wanted to be 100% sure that I wasn't missing out on an opportunity to get even better fuel economy. That's why I posted.
    Thank you all for your insightful replies.
    swaan Thanks this.
  10. rbrauns
    164
    56
    Dec 7, 2014
    BTW the truck has already been deleted by the previous owner and tuned. It puts out 517 hp to the wheels and makes 1847 ft lbs of torque.
    Redoing what was already done makes me wonder where the smoking gun is....
