Can/how to remove a empty box when the PTO went out
Discussion in 'Waste Removal and Garbage Truck Driver Forum' started by Pojo1666, Apr 20, 2020.
  1. Pojo1666
    Pojo1666 Bobtail Member
    Apr 20, 2020
    I work for the county minutes for waste we had a truck have the PTO go out with a box stuck on the back and before we can take it for service they said they wanted the box off the back trying to figure out how to get it off without having a PTL
    truckdriver31 Thanks this.
  3. Biomagnum
    Biomagnum Light Load Member
    68
    135
    Jun 7, 2013
    Use a separate hydraulic pump tapped into the lines and bypass the PTO pump.
    AModelCat and truckdriver31 Thank this.
  4. GreenPete359
    GreenPete359 Road Train Member
    2,277
    5,477
    Oct 21, 2017
    Driving my recliner
    Pick the front of the box with 2 forklifts one of each side. Back another roll off up to it & use a chain to his winch.
    If you have a winch system...You have to the front of the can past the locks.
    if you guys have just the hook system i have no clue. No experience with them.
    edit: Or call a wrecker company to come out & lift the can off & place it on the ground.
    AModelCat Thanks this.
