Can I use the power post for cooking
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Dieseltu, Jan 13, 2019.
  1. Dieseltu
    Dieseltu Light Load Member
    55
    27
    Sep 10, 2015
    Morning, Im wanting to use a Hot logic or crock pot in my box truck. There's these two black and red power post not being used. The GPS is being run of a cigarette lighter. Im also assuming they are factory . Can I assume they are at least a 15 amp install. And if i make the correct connections on my cooker i can install and remove them daily. and even use an inverter there. The truck is an Intl box truck. i can go either way with the voltage. But i just realized I have a 300 Watt 120 v rice cooker that would work awesome.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    12 volt and 15 amps is not the same as 120 volts driven by 15 amps.
    Also your alternator will produce a output and that is all you get.
    When you state the kinds of appliances, that is wonderful, however; it will be helpful if you stated they were designed to work at 12 volt or house power 120 volt.
  4. Dieseltu
    55
    27
    Sep 10, 2015
    i can go either way with the voltage. But i just realized I have a 300 Watt 120 v rice cooker that would work awesome. I dont want to make a problem for the company. I guess I need to figure out how much power is supplied there .
  5. SteerTire
    SteerTire Road Train Member
    1,414
    2,347
    Nov 5, 2018
    Behind the wheel
    Are these post on or near your dash? If so, they’re for your CB. And fused at 20 amps tops
  6. Dieseltu
    55
    27
    Sep 10, 2015
    I found this. conversion
    12 volt to 120 ac conversion
    Wattage is volts X Amps. A 120 volt inverter needs 2.5 amps to make 300 watts. Power stays the same no matter how you convert it. ( With probably a loss for heat because nothing is 100% effective in converting power) To get 300 watts of 120 volt AC power out, you would need to draw 25 amps of 12 volt DC from the cigarette lighter! ( both equal 300 watts) Does your cigarette lighter have a 25 amp fuse and 10 gauge wire?
    The wattage thru a car cig lighter/outlet is limited by the outlet’s amp fuse rating. So most car power outlets are limited to 120 watts (12 V x 10 amps) or 180 watts (12 v x 15 amps) based on most car power outlets having a 10 or 15 amp fuse.
  7. Dieseltu
    55
    27
    Sep 10, 2015
    Yea theyre in the middle. CB post. So the max I could get is 240 watts of 120 volt power without compensating for efficiency losses , ect. So the rice cooker is out, so is the lunch box cooker. The hot logic draws 45 or 65 watts at 120. Which should be around 4-6 amps of 12 volt. So i could do this with a inverter.with cb connections its well within the limits of the cb connections. And I #### sure wouldnt be getting the alternator and batteries attention. Right?
  8. SteerTire
    1,414
    2,347
    Nov 5, 2018
    Behind the wheel
    I use a lunch box cooker with my outlets. Often times I start the truck, it seems to help. I’ve never tried a direct wire setup
  9. Powder Joints
    8,098
    8,643
    Sep 25, 2007
    Rosamond, SoCal
    Factory for those cb fuse's 15 amps, check the wire gauge, your going to melt it. Nothing like the smell of burnt wire in the morning
    Cattleman84 Thanks this.
  10. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    No one who has driven old iron long enough has not had a fire along the CB power cords for a variety of reasons. That kind of event usually gets people going in a hurry as the cab fills up with flame and smoke at 70+
  11. truckdriver31
    6,998
    8,365
    Sep 18, 2013
    okay listen up fellow truck stoppers. im only going to say this once. if you every want a inverter or 120 volt power stuff in the truck. you need to follow this format. ampsx117=watts. u dont use all of 120 volts or all of a 20amp breaker. so use 117 volts. but the key is amps x 117 volts will = the watts you will use. remember start up amps and running amps are different. start up amps are like fridges and ac uses higher start up amps. so 5.6 amps would be 655 watts. etc.
