Can Maxxforce 13 fuel pump leak
Discussion in 'International Forum' started by Jhncp, Jun 24, 2022.
  1. Jhncp
    Jhncp Bobtail Member
    41
    Feb 4, 2020
    2010 still wondering if it can be leaking fuel into oil from pump through auxiliary drive
  3. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    The pump is internally lubricated and cooled by fuel pressure. I guess if the input seal let go, it could pour fuel right into the crankcase from the aux drive. If you put dye in the fuel, you should be able to remove the aux drive pulley cover and look inside with a UV light and see if there are traces of dye in there.
    stuckinthemud and Magoo1968 Thank this.
