Can Of Worms!!!!
Discussion in 'Ask An Owner Operator' started by 7mouths2feed, Feb 17, 2008.
  1. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Hello All, I know I am opening a can of worms with this question but......
    Everyone has their personal opinions but put yourself in my shoes for just a moment and remove any prejudices you may have on this subject..
    "You" are looking for god used daycab(<$20k) to haul logs in N. FL... Keep in mind --no hills over 30ft:biggrin_2559:, mainly 2-lane roads=55-60mph, minimum (less than 1/2 mi) off road. What would you look for re: specs.....Cat-3406e/c-12/c-10, Detroit 60, Cummins N-14? Tranny 9,10speed, Gears 390,411,433???? The items I have listed are what seems to be out there In my price range...One day I hope to pick out "my" perfectly spec'ed truck but for now I have to deal with what is out there.
    PS-Cat guys please keep in mind we are looking for the best overall package, so milage counts.:biggrin_25525:
    One truck inparticular is a N14/410hp, 9spd,w/433 gears. The gears scare me milage wise...But then what kind of milage can one expect running 100-300mi RT, stop and go through small towns all the time.:biggrin_2556:
    Thanks to you all. I :biggrin_25514: to all the knowlege you have extended to everone in this forum.
    In response.
    I am totally ignorant to the Macks. I see alot with 350 hp mack engines. How do these compare to other 350hp ranged engines? Should I still look at 400 plus Mack? Also many Macks have 5,6,7 speed tranny's.. Why so few gears?
  3. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    with a 9 speed you will want them low gears. You wnt low gearing for off road work. lower the better. Of course the best thing would be a deep reduction tranny but you'r $20k will limit what you can get.
    My uncle is a logger and he will only run macks. His son has some KW's. these days it's a wash I guess since Mack isn't what they once were.
  4. Lucifer
    Lucifer Light Load Member
    73
    14
    Jan 1, 2008
    The Morning Star
    R Model Mack. Think R685ST or R686ST. Try to get a 2 valve engine, and a TRL107 or TRXL107 trans. Mack 4.17 rears on Mack Camelback suspension.
    With even slight care, that truck will still be running when we are pushing up daises.
    I take it you are hauling pulpwood for paper? There is one for sale in Bristol Fl.
    I'll bet you can buy it for 5 or 6 G
  5. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I have seen that mack camel back do things offroad I never thought possible. I drove a rollback truck with one and it went through stuff I wouldn't take my offroad jeep into.
  6. Lucifer
    73
    14
    Jan 1, 2008
    The Morning Star
    Yeah that was back when a Mack was a MACK. I am starting to see a lot of R Models around. The South American export market for them has picked up again too.
    If you want a good bulletproof one, Get one with an ENDT675 or Endt676 Engine. Look at the pump, you want one with an American Bosch APE 6BB110T pump. Robert Bosch would be a good 2nd choice. Try to stay away from the American Bosch or Ambac PLM pumps. The PLM pumps were a little weak in the cam followers. If you turn them up much the rollers wear right out.
    You want a 5 or a two stick 6 speed trans. Stay away from the Mack 2090 trans or any of the other 20 series trans, the syncro in the back end of them always went bad.
    It's a shame what happened to Mack. They are pretty much a re badged Volvo now.
  7. Lucifer
    73
    14
    Jan 1, 2008
    The Morning Star
    The 350 engines were ok but a 300 Maxidyne will run right along side one and using only 5 gears. the 350s and 400s needed at least 9 gears.
    The 2 most desireable engines are the ENDT 675 (237 hp MAXIDYNE), The ENDT676 (300 HP Maxidyne) as far as the later 4 valve engines go the EM6-300 Maxidyne was about the only good one.
    The Mack Maxidyne engine had a very wide powerband that is the reason it can run with only 5 gears.
    With a slight fuel pump recalibration, even the 237 HP Maxidyne will run right along with anybody elses 350s and 400s.
    I once had a 237 that put out 375 HP on a chassis dyno.
    BTW are you running over to PCA Valdosta with that wood?
  8. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I get SO lost when we start talking Macks. They were a creature all there own and have so little knowledge of them.
    My uncle is so unhappy with the macks he has had in the last few years I don't expect to see many more around. he's had them back to the factory looking for problems they never could find. They never used to have problems with them and now they can't seem to keep them running
  9. 7mouths2feed
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Typically running to Container and Raynier in Fernandina Bch, FL. Of course if they say haul it to Mickey town, I guess I'll head there..:)... I've steered away from Macks due to my total ignorance of them.. I see 237/300/350hp and I'm thinking "3klbs styrofoam coolers" not 50k in logs.. Also I see ??Mack Truck with a 5/6 spd???? my Toyota has a 5spd tranny.. How's that possible? LOL
  10. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    There is a reason you see o many mack dumps, log trucks, etc. they are the undisputed off road champions. with the roll offs I mainly drove a volvo heavy chasis th eother guy had a mack and even with his differential lock not working he could get further into the landfill after a rian with one axle than I could with both. I don't know what it is with that suspension but it works.
    I'm more familiar with the ten speed with the deep reduction, and the 15 speed but we had a "loaner DR mack with a 5 speed and I hated that darn thing. It was god in the landfill but if you had to go on the road it just didn't work for me. then again it had no shifting diagram and it was some wierd thing like 3 on the bottom side and two on the high side or soemthing. Never did figure it out right
  11. 7mouths2feed
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    My only knowlegde of Macks was when I was 14 , more yrs ago than I care to say.:biggrin_25524: I drove the woods truck hauling loaded trailers out to the road and back with empties.. Think it was a '65 with a 2 stick.:biggrin_25510: .. ????.Maxidyne.. :biggrin_25511: I think
    They had to add blocks of wood to the pedals so I could reach them. :biggrin_2559:
    Looking through truckpaper FL, GA, SC, NC, AL, MS, TN I see numerous mack 350hp 10 spd in my price range (<$20k.) Some 427's, 400's. But Macks all look Greek to me.
